Aux light switches and firewall (WK) - JeepForum.com
post #1 of 2 Old 06-21-2009, 06:55 PM Thread Starter
ncarlson
2006 WK
I am going to install aux lights on my WK, but want the interior to look as clean as possible. Can anyone suggest a good place for aux switches? Also, where would be the best place to get through the firewall without drilling?
Any pictures of installed switches would be appreciated!
ncarlson is offline
post #2 of 2 Old 06-21-2009, 10:41 PM
jaw22
2011 WK
I just put a sub into my 05. Right above the brake pedal slightly to the left if you take off the plastic mud cover, you'll see a rubber circle. You can break through it to wire into the battery, or you can go around it. I will try to take a picture tomorrow when its light outside.
Be careful, this is VERY close to the brake lines and other juicy stuff like that. I went around the rubber circle, duct taped the power cable to the amp to a wire coathanger and navigated through towards the battery, then removed the tape and hanger. If you go through the rubber though, it will be less likely that grime/water will get through and leak inside. The rubber is pretty thick and not easy to get through.
If you do it like this, the best place to install an aux switch is in the little cubby hole to the left of the steering wheel. I never use it anyway. Hope this helped.
jaw22 is offline
Getting through the firewall in 99 WJ Kheeney5 ZJ Grand Cherokee Forum 0 12-16-2009 06:55 PM
Were'd you guys put your aux light switches? gmp211 ZJ Grand Cherokee Forum 8 06-10-2009 12:56 AM
WJ firewall Arkansas_WJ ZJ Grand Cherokee Forum 6 12-20-2006 05:50 AM
Firewall help madcabbie ZJ Grand Cherokee Forum 4 01-30-2006 12:43 AM
firewall rJEEP ZJ Grand Cherokee Forum 7 01-21-2003 10:45 PM
