Anyone use Waterless coolant? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Anyone use Waterless coolant?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSavvy Aluminum Gas Tank Skid
Unread 08-27-2014, 04:50 PM   #1
TangoTango
2008 WK
Anyone use the waterless coolant?
They say you never have to change your collant again.
Video here:
TangoTango is offline   Reply With Quote
Unread 08-27-2014, 05:15 PM   #2
colinzj
2006 WK
Wow. Their FAQ is the snake oiliest.
I think it actually sets a new record for how much I've seen a manufacturer abuse science and logic.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Unread 08-27-2014, 05:57 PM   #3
caddydaddy
2007 WK
I was reading some reviews and most people liked it. Some complained that the heater didn't put out as much heat in the cold as with regular anti-freeze. That's a no-go for me! haha
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is offline   Reply With Quote
Unread 08-27-2014, 07:06 PM   #4
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Video here:
Video Link: http://www.youtube.com/watch?v=t7PykrgzWPQ
You don't HAVE to change your coolant as it is. If you want a good and proper, well maintained cooling system you will.
I wouldn't trust this stuff.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
Unread 08-27-2014, 08:15 PM   #5
TangoTango
2008 WK
I was just wondering...if anyone here actually used this?
I'm not really thinking of trying it. Even without water I still can't see the product not breaking down over time.
Unread 08-27-2014, 08:33 PM   #6
Jonathanjr1
I don't think this stuff is worth it. For 4 gallons of waterless coolant you can get 10 of gallons of regular coolant concentrate. So as for cost you could change you coolant every 5-6 years for 30 years with standard coolant for about the same cost as this stuff. If your car ever has a leak with waterless colant you have to fill it up with that, if you don't you can lower the boiling point and cause other problems. With the regular collant you could top it off with water for the mean time then you add coolant to it to bring it back to the right mix.
Jonathanjr1 is offline   Reply With Quote
Unread 08-27-2014, 08:35 PM   #7
Chirpz
Chirpz's Avatar
2007 WK
Is that made out of coconut oil? Or is is more like Almond milk?
[B]Chirpz[/B]
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote
