Anyone else with the windshield washer nozzle problem? - Page 3 - JeepForum.com
post #31 of 100 Old 08-10-2011, 11:25 PM
suzieque
2008 WK
guys I recall driving through the dealership lot a year ago and I could've swore the 300c has metal (aluminum?) washer sprayers. perhaps check with the parts guy if you are buying a replacement washer sprayer, you really don't want to simply buy plastic again.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #32 of 100 Old 08-10-2011, 11:35 PM
WKDiesel
Are the hole size that the nozzles fit through a universal size
WKDiesel is offline
post #33 of 100 Old 08-11-2011, 12:24 AM
TurboDiesel
2008 WK
im pretty sure my 300 had plastic ones, but it is something to ask about for sure
or try and find metal ones that can fit...
i dont know if they are universal...
TurboDiesel is offline
post #34 of 100 Old 11-16-2012, 08:38 PM
SCD23x
Anyone find a better nozzle? My right one broke at the connector.
SCD23x is offline
post #35 of 100 Old 11-16-2012, 08:52 PM
TurboDiesel
2008 WK
i bought these
http://www.ebay.ca/itm/05-12-Toyota-...-/160828560547
basically just looked for a set that looked the same as my stock set
these fit and work great, spray is alittle different but atleast i get spray lol
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
post #36 of 100 Old 11-16-2012, 08:55 PM
SCD23x
Originally Posted by TurboDiesel View Post
i bought these
Thanks Turbo
SCD23x is offline
post #37 of 100 Old 11-16-2012, 08:56 PM
TurboDiesel
2008 WK
no prob
figure i would try it out seeing as u get a pair for cheaper than 1 lol
post #38 of 100 Old 01-04-2013, 10:10 AM
TMAH
2011 XJ Cherokee
Just dropped my 2011 Jeep Grand Cherokee off at the Capital Jeep in Edmonton... the nozzles on both sides cracked right off. Dammit!
TMAH is offline
post #39 of 100 Old 01-18-2013, 04:22 PM
eprovenzano
2005 WK
I just replaced both nozzles. The passenger side did not work, as it was broken I pulled a little to hard on the hose when installing the new nozzle and broke the driver side nozzle. I'm glad I bought two nozzles, as I planned to replace both of them anyway, I can now clean my windshield. Yes they are very pricey, ($21 each) but its something you have to have.
2012 Grand Cherokee Limited Wk2 (Momma's)
2005 Grand Cherokee Limited, WK, 4.7 V8 currently rolling on Cooper Discovery 265 70 17's, with 1.25" spacers.,installed an OME HD lift sourced through Kolak.
1996 XJ 6 inch lift on 33's (Son's)
eprovenzano is offline
post #40 of 100 Old 01-19-2013, 10:43 AM
suzieque
2008 WK
i bought these
I bought these as well and keep them in the glove box in case mine fail on the road.
suzieque is offline
post #41 of 100 Old 01-21-2013, 10:19 AM
TurboDiesel
2008 WK
they have a different spray pattern, but work awesome....no issues with them so far
post #42 of 100 Old 08-15-2013, 01:03 PM
sfeinsmith
2007 Grand Cherokee Overland WK Nozzle Problem
I had dealer replaced right side (passenger) windshield wiper nozzle because it cracked and disattached plastic tube with piece of nozzle plastic tube and then profound leaked. This was second time replaced and then sudden left side (driver) broke same way as right nozzle. I inspected as confirmed the plastic nozzle assembly was poor designed by Chrysler and allow it break off easily. The first one as they charge me near 60 dollars to replace the nozzle. The second nozzle was replaced under warranty but driver nozzle, again they want to charge me 60 dollars for a little job to replace the nozzle. I discovered Chrysler charge for the replacement nozzle was very high. I reported to Chrysler about nozzle problems several times and they just simple ignore this incident.
It is good time for you to speak out and file with NHTSA. I almost lost my Jeep as mud hit my windshield and unable to wash off because of broke nozzle again and again. This is sake for safety.
Thank you
sfeinsmith is offline
post #43 of 100 Old 09-04-2013, 10:41 AM
miles85
2008 WK
I have a similar issue with my wiper fluid system. The hose running between the two nozzle cracked in half and now no fluid comes out the nozzles. It just dumps on top of the engine. anyone had to replace the hoses??
miles85 is offline
post #44 of 100 Old 09-06-2013, 08:38 PM
Walt
2008 WK
Just replaced my passenger side spray nozzle assembly. It broke off at the nozzle connection and the tubular plastic piece stayed in the fluid supply hose.
The plastic nipple was brittle and came out in little pieces. Mine had a build date of Sept. 2007, so I'm thinking the nozzle just aged and got brittle from heat/cold exposure.
It was ~$22.50 (pricey). The shop manual says it has a check valve integral with the assembly.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #45 of 100 Old 09-07-2013, 10:13 AM
Goldenknob
2007 WK
I thought my drivers side was broken, so I bought a new pair. When I went to put the new one in, I found out it had just came unhooked, lol. Now I have two brand new spares, Yay!
Goldenknob is offline
How do you take the rear washer nozzle off ? Candymancan ZJ Grand Cherokee Forum 0 02-23-2011 02:22 PM
Windshield washer mystery...... 96 ZJ Smedly ZJ Grand Cherokee Forum 4 08-23-2010 12:32 PM
windshield washer problem oldflyingfarmer WK Grand Cherokee & XK Commander Forum 5 06-29-2009 02:22 PM
Rear Window Washer Nozzle augnmike ZJ Grand Cherokee Forum 2 05-25-2008 11:58 PM
'93 GC windshield washer cobra652004 ZJ Grand Cherokee Forum 2 02-22-2004 08:18 AM
