Anyone with an 05 & 545RFE - JeepForum.com
post #1 of 17 Old 04-02-2012, 09:05 AM Thread Starter
yzjwk
2005 WK
I'm pretty sure with the 2006-up and 545 , when you use the auto stick , the first click left (downshift ) from D indicates 5 on the display .My 05 however indicates 4th gear .The owners manual indicates that this is the way it was supposed to operate but i was just wondering if everyone elses 05's did the same ?
Thanks in advance
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #2 of 17 Old 04-02-2012, 10:09 AM
lsuber
2005 WK
I've got an '05 with that transmission (Rocky Mountain Edition), and I'm pretty sure mine goes straight to 4th gear on the first left click with the shifter. But I'll check that when I get in the car this afternoon. Seems like our '06 Commander does the same thing as well.
2005 WK Grand Cherokee, Rocky Mountain Edition, 4.7L V8 4x4 QTII
2006 XK Commander, 4.7L V8, 4x4 QTII
lsuber is offline
post #3 of 17 Old 04-02-2012, 10:47 AM
colinzj
2006 WK
Fifth gear is overdrive, which you're disabling when you make your first manual shift (to 4). D is 5.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #4 of 17 Old 04-02-2012, 11:06 AM Thread Starter
yzjwk
2005 WK
Yes , but when you make the first manual shift in your 06 , you should be in 5th gear, not 4th like the 05's .At least all the 06's and up i remember test driving were like that .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 17 Old 04-02-2012, 01:15 PM
trax95008
2006 XK Commander
I'll check my 06 XK when I get off work. That does seem odd, as dropping to 5th would be pointless...
trax95008 is offline
post #6 of 17 Old 04-02-2012, 04:44 PM
modernblueWK
5th Is overdrive with the tc not locked up.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #7 of 17 Old 04-02-2012, 05:08 PM Thread Starter
yzjwk
2005 WK
exactly , and i believe it also disables mds if you have it .I was just wondering if it ever came out in the 05 model year .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #8 of 17 Old 04-02-2012, 08:32 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Both 4th (.75:1) and 5th (.67:1) are overdrive gears on the 545RFE transmission. The 05's, 06's, and I believe 07's do not show "5" when backshifting. They only show "4". Walt, or someone with an 07 or 08 may be able to verify what year the "5" started showing up. I thought I'd be able to get it with one of the tuners like I did with my LX, but it still doesn't work on the WK. The shift lever must be in "D" for the MDS to work.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #9 of 17 Old 04-02-2012, 08:52 PM
LordEnki
2006 WK
06 tap once to left puts me in 4, tap to right again puts me back in D.
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #10 of 17 Old 04-03-2012, 06:46 AM
hillj28
2005 WK
My 05 goes to 4th after one tap.
hillj28 is offline
post #11 of 17 Old 04-03-2012, 07:03 AM
lsuber
2005 WK
Checked my two Jeeps, and they both go to 4 with the first left click.
lsuber is offline
post #12 of 17 Old 04-03-2012, 07:30 AM Thread Starter
yzjwk
2005 WK
I know for sure the 07 registered 5 , because i never test drove an 08 , but i was pretty sure the 06 did as well , ooorr maybe i'm just loosing it all together . lol .in 06 they supposedly changed the transmission to allow for better shifting , but i haven't been able to find what they did to acomplish that .As well in my reserch i found that the up-shift and down-shift pump pressures are different/higher for the hemi as opposed to the 3.7(liberty)/4.7's which i find odd because from the research i've done ,the 545 is basicly a hydraulicly operated trans up to 3rd gear .I'm just looking at tuning/valve body options to make the trans on my hemi a little better suited for me .the superchips helps , but still not everything it could be IMO .
thanks for the replies everyone .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #13 of 17 Old 04-03-2012, 08:00 AM
trax95008
2006 XK Commander
My 06 XK drops to 4th with one tap to left
post #14 of 17 Old 04-03-2012, 11:05 AM
90grandoneer
2006 WK
Yzjwk, I hear you on the "loosing it". From time to time I have the same problem. Just hope it never becomes permanent. On the "better shifting", if they did it, I'd like to know what the earlier ones are like. Stock, my 06 was absolutely terrible. I added the Sonnax Line Pressure Booster and the tuner, and that helped somewhat. Then I just recently started tinkering with the SC ATT App. and improved it some more. It's almost too sensitive now, but I noticed on a short trip yesterday it still can't figure out what to do when go WOT at about 60 mph. Big hesitation that's always been there is still there. Other than that I am now fairly happy. It is, however, nothing like the NAG1 in my Hemi LX. It is a true autostick with instant response at any throttle setting, plus it'll take your head off on the WOT upshifts yet is very smooth at light throttle. Wish the 545RFE was half as good.
post #15 of 17 Old 04-03-2012, 11:09 AM
croth
2005 WK
My '05 also goes from "D" to "4".
croth is offline
545RFE gasket? chrisstromberg ZJ Grand Cherokee Forum 4 03-23-2009 11:42 AM
231 T-case behind 545RFE Wheelin98TJ WJ Grand Cherokee Forum 13 02-13-2009 09:14 AM
45RFE vs. 545RFE the88thpianoman ZJ Grand Cherokee Forum 3 06-06-2008 06:50 PM
545RFE-Any changes? Dieseljoe WK Grand Cherokee & XK Commander Forum 4 04-11-2008 08:45 AM
545RFE-Is it any good? Dieseljoe ZJ Grand Cherokee Forum 6 10-25-2005 07:40 PM
