Any you brothers ever get ABS Lights on? - JeepForum.com
post #1 of 5 Old 07-11-2013, 09:52 AM Thread Starter
Ruckus02
I have codes: U1417 and C102A
I have replaced front wheel sensor and checked ABS 10a fuse and ABS pump 30 amp fuse. Any suggestions? 06 V6 AWD
Ruckus02 is offline
post #2 of 5 Old 07-11-2013, 11:02 AM
scott02ws6
2005 WK
I'm actually dealing with this right now, the U1417 is front left (driver) side, make sure you did left not right. On mine, I have a obd2 code reader but I'm not pulling any codes for the issue, my question is, did you use a normal obd2 reader to get your codes or did you have the dealer use their starscan system to read the abs system? If you have already switched out the wheel speed sensor, have you verified the codes again after the change?
05 WK-HEMI-QDII-flowmaster-intake-RC 2" BB-F150 MLL-mesh grill mod-grill mounted LED drive lights-LED cargo mod-Brush/push bar
02 Trans Am WS6 - 482 rwhp (motor) 642 rwhp (N2O wet) AIR ASSAULT!
scott02ws6 is offline
post #3 of 5 Old 07-11-2013, 12:26 PM
yzjwk
2005 WK
From the service manual :
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
NOT front left .C102A-LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE
C102A is your ABS code that you should be troubleshooting , not the communications code . save yourself some time and money and get a service manual on line so it can walk you through .
Good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 5 Old 07-11-2013, 12:35 PM
scott02ws6
2005 WK
Good luck
Ahhh gotcha, I must have read it wrong. I have a service manual and forums like these assist with info as well
post #5 of 5 Old 07-11-2013, 03:04 PM
toycam
I get a U1417 code every now and again. It's always cleared itself within the next couple start ups. I guess that's a sign that the sensor is on its way out the door.
toycam is offline
