Any Gotcha's with front Lower Control Arm Replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Any Gotcha's with front Lower Control Arm Replacement
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 07-31-2014, 10:58 PM   #1
DeChache
2003 WJ
As the title says. I will be replacing the front LCAs on my 08 this weekend are there any gotcha's I should know about?
I already have everything ripped apart from a strut change. Just need to pull off the old arms and put the new ones on.
I'm changing them because of rust issues. I spent two days trying to get the strut clevis bushing out said screw it and bought new LCAs.
I've done this before on the WJ just new the the Independent front of the WK
His 2003 Limited 4.7 QD 145K
Hers 2008 Laredo 3.7 QT1 119K
DeChache is offline   Reply With Quote Quick reply to this message
Unread 08-01-2014, 08:17 AM   #2
DeChache
2003 WJ
Not seeing anything would anybody be interested in a write as I do this tomorrow.
Unread 08-01-2014, 08:38 AM   #3
IIMacGyverII
IIMacGyverII's Avatar
2007 WK
You might as well do a write up then put it in the Tech Tips DIY sticky for the next person looking for it. Someone will be grateful.
http://www.jeepforum.com/forum/f67/t...e-ups-1480838/
2007 WK CRD Limited Fully Loaded. GDE Hot Tune, SWK Member 115
1996 ZJ Limited -RIP
N23 Recall Victim
IIMacGyverII is offline   Reply With Quote Quick reply to this message
Unread 08-01-2014, 06:17 PM   #4
Jeep Brian
I would love a write up!
Mine: 07 GC Limited Hemi stock for now.
Hers: 14 Dodge Durango Citadel Hemi
68 Firebird 350 4 spd #'s matching
Jeep Brian is offline   Reply With Quote Quick reply to this message
Unread 08-01-2014, 08:25 PM   #5
DeChache
2003 WJ
I'll take the camera out with me tomorrow. Look for something on Sunday I have family coming tomorrow night so I prob won't get the write up done until then.
Unread 08-01-2014, 09:41 PM   #6
IIMacGyverII
2007 WK
BTW, Nice car. I have a 67 Firebird with the 400. Mostly done but not numbers matching.
N23 Recall Victim
Unread 08-01-2014, 09:43 PM   #7
scootter82
2009 WK
Definitely! I have a set of lca's in the closet, waiting to be put on whenever I find time. Have never changed any out before, so I'd appreciate seeing how it's done before hand!
Edit: definitely want to try this myself as the shop quoted me around $300 per side to replace these!
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline   Reply With Quote Quick reply to this message
Unread 08-08-2014, 01:35 PM   #8
DeChache
2003 WJ
Hopefully finishing the job tonight. Work got crazy on me. I haven't forgotten about the write up
Unread 10-02-2014, 08:34 PM   #9
DeChache
2003 WJ
Finally got the write up done. I made it its own thread.
http://www.jeepforum.com/forum/f67/h.../#post25871602
