Another Turbo Underflow Error - JeepForum.com
post #1 of 12 Old 06-13-2017, 08:52 AM Thread Starter
GrandSteveO
2008 Jeep Grand Cherokee 3.0 CRD Just turned 400k
I have a turbo underflow issue. I have tried the 4.7k resistor fix which seemed to work for about a month now the issue is back. replaced the resistor again but did not help. Looked online and saw the turbo actuator could be bad, took it apart and all seems fine and it works when engine rev'ed etc. The Limp mode happens around 80k or 50mph but I can quickly turn off/on key and the lightning bolt still flashes but I regain power. at low speeds it does not seem to happen. At time the jeep hesitates at 50mph like there is a heavy load but once past it is fine. Any thoughts on what it could be? I have heard if the Swirl motor is really bad it sends a weird signal somehow even if it has the fix mod. any help would be appreciated. I have had in the shop and over $600 later they have no clue.
I also have every glow plug saying there is an error in the circuit
My codes:
P0299 turbo underfloor error
P0674 glow plug
P0402 exhaust gas flow detection
P0676 glow plug 6
P0675 glow plug 5
P0672 glow plug 2
P0671 glow plug 1
P0335 crankshaft position
P0674 cylinder 4 glow plug circuit
P0676 cycling 6 glow plug
P0675 glow plug circuit5
P0672 glow plug circuit 2
P0671 glow plug 1
P0299 turbo super charger underfloor
So lots going on
GrandSteveO is offline
post #2 of 12 Old 06-14-2017, 11:58 AM
Donuts31
I've got the same issue. If your turbo actuator has never been rebuilt, it should be sent out. The actuator initially fails intermittently and randomly before it quits altogether. Did you have full range of movement on the the turbo VNT rod that is connected to the actuator?
If a turbo actuator doesn't fix it (and doesn't fix my issue) then I will then replace the EGR throttle valve next. I figure I can throw parts at the Jeep cheaper than any dealership can and I have better knowledge then most Jeep techs do anywhere. I also installed a new resister just in case for the swirl motor. The previous resistor has been in there for about 45k miles and it could be damaged from heat exposure.
I also did get the crankcase position sensor code and replaced it. These go bad often and are easy to replace.
GOod luck with your issue and I'll let you know how mine works out. Hopefully we can both figure out what is going on.
Drew
Donuts31 is offline
post #3 of 12 Old 06-16-2017, 07:02 PM
omsok
omsok's Avatar
2007 WK
I am having same issue, just popped up after rebuilding alternator. Wondering if ti is better to just buy a new Turbo and actuator complete in case the turbo is going to let go in the near future anyway. http://www.idparts.com/garrett-turbo...gt-p-2786.html
omsok is offline
post #4 of 12 Old 06-16-2017, 09:33 PM
caddydaddy
2007 WK
How many miles on your turbo? Mine had a chewed up impeller from debris, but was otherwise fine at 194k miles. I installed a rebuilt one that looked as good as new from XSBoost.com about 3k miles ago when I replaced the oil cooler seals.
They also sell rebuilt actuators.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
196,000+ miles!
caddydaddy is offline
post #5 of 12 Old 06-17-2017, 12:04 PM
stev0
2007 XK Commander
If the swirl goes bad, what sort of codes could I be looking at? If I had the swirl disabled in the tune (gde) would I still get codes ?
07 XK CRD - (GDE Tuned)
stev0 is offline
post #6 of 12 Old 06-18-2017, 08:31 AM
omsok
omsok's Avatar
2007 WK
Actuator rebuild vs Turbo Replacement
At the moment, only 86'000 miles, 140'000 kms. I know it is not really a lot, but just thinking ahead. There is a guy here that will rebuild for about $200, so for that price I guess it is worth it. http://jeepturboactuator.com/
omsok is offline
post #7 of 12 Old 06-18-2017, 09:21 AM
stev0
2007 XK Commander
My xk has the same sort of miles on {145k km} and am di have the same issue. I've just swapped the actuator for a used one and it worked for about a day. I have a feeling it needs to be soldered as my original had the contacts broken. No idea why they break... This one lasted about a day.
stev0 is offline
post #8 of 12 Old 06-18-2017, 07:04 PM
caddydaddy
2007 WK
I have seen that rebuilder before. Doesn't sound too bad of a deal, since XSBoost is now charging $600 for a rebuilt one.
That intake pipe set up have you have is sweet! Do you have a parts list of what you used to assemble it, or was it custom bent, etc?
2" RC lift
196,000+ miles!
post #9 of 12 Old 06-19-2017, 10:53 AM
08rubie1
Tell me more about ur intake!
08rubie1 is offline
post #10 of 12 Old 06-19-2017, 04:11 PM
Brit30-06
2008 WK
Hi.
My code was P1270 when my swirl motor packed up.
Brit.
Brit30-06 is offline
post #11 of 12 Old 06-19-2017, 07:33 PM
omsok
omsok's Avatar
2007 WK
Air Intake mod
I didn't do a build thread for it, but basically figured out what I would need, went to a Turbo tuning shop and bought the pieces. I took the air intake pipe with me, and had a list of what I thought would work.
In retrospect I should have just bought it all online. I was trying to give business to a local shop, and expected a little service. Drove 90 minutes and the guy in charge passed me off to boy wonder who ended up to giving me exactly what I needed and then gave me two different styles of pipe clamps. One is 10 mm and one is 11.
When you blow a turbo boost pipe (I did turbo resonator delete at same time) on the highway and want to put it back on quickly on a hot engine, you do not want to be wondering if that is the 10 mm or 11 mm socket. Anyway, I think I have photos, so will put up a writeup on my blog.
http://www.engineeredobsolescence.com/
Started thread here:
http://www.engineeredobsolescence.co...2&preview=true
Will add to it.
I just added a few photos I had handy, but will explain what they mean in next week or so on blog. The air intake change was meant to coincide with oil catch can mod, but let me tell you from my experience this mod may be more of a PITA than it is a benefit. Recently I pulled my Intercooler, drained it, washed it with hot water and oil cutting soap and got almost nothing out of it. After 85'000 miles and nine years, less than an ounce of oil tells me not to worry. The small Mishimoto meant for V8 Chevy is useless on the Diesel.
Photo of 33 degree bent pipe with stepped end is CB engineering photo, but I just bought a pipe pre bent to that angle, and rolled my own beads with vice grips and washers or muffler clamp, can't remember. Anyway will do writeup.
Cheers.
omsok is offline
post #12 of 12 Old 06-19-2017, 07:38 PM
omsok
omsok's Avatar
2007 WK
Turbo Actuator.
There is a guy in Montreal selling German rebuilt for $400 CAD. Not quite sure what the deal is.
http://www.kijiji.ca/v-moteurs/laval...ationFlag=true
omsok is offline
limp mode
