annoying spare tire low message won't go away - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > annoying spare tire low message won't go away
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 02-23-2013, 05:11 PM   #16
Muddy4DSM
Need to bring up this old thread again. I have an 06 WK limited and recently went through a headache with replacing my TPMS sensor for my spare. Anyways, got it replaced this week, drove for a few days with the "spare low pressure" warning. Got a tip to swap out the wheel with one of the others so I did that this morning. Oddly enough, the wheel with the new sensor is transmitting the pressure to my TPMS display on my dash, but is still telling me the spare is low. I think it's sitting at around 32-33 lbs so it not low. Any idea how long it takes to reset or is there something else I should be doing?
Has anyone discovered where the reader for the spare sensor is located? Maybe it can be unplugged to be reset or replaced? I don't think it needs replacement since it worked just a few months ago when the spare pressure actually got low because of a broken stem an was then replaced recently.
OO|||||||OO
Muddy4DSM is offline   Reply With Quote Quick reply to this message
Unread 02-23-2013, 08:39 PM   #17
odell
Junior Member
odell's Avatar
Hey Muddy, guess I could have update this thread awhile back. I took my commander to the dealer and for 70 bucks they reprogrammed the sensors and all better. They tried to tell me the sensors I bought weren't compatible with my model but I gave them the part numbers off it to set them straight. I hated paying the money, but glad to get the annoying spare tire low message off my dash.
Black 03 sahara with some stuff.
odell is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 11:35 PM   #18
SaskHemi
2005 WK
I'd really like to get rid of it too. Checked my spare and it was way overinflated, PO probably kept adding air to try and get the warning to go away. Adjusted all tires to correct pressure and like many others the warning is still there.
When you say they reprogrammed the sensors, what exactly do you mean? Did they reprogram the system or the sensors themselves? I'd like as much detail as possible so I can clearly instruct the dealer about what I want done.
Thanks!
2005 WK Limited, Black, Hemi, QD II, RC Leveling Kit
SaskHemi is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 11:38 PM   #19
WieSeL
Do you have a psi readout or just the idiot light? The sensors with just the light are self learning. Think your sensor went out in the spare
WieSeL is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 11:40 PM   #20
SaskHemi
2005 WK
I have the premium system with psi reading for the drive wheels, but not for the spare.
Unread 08-25-2013, 09:48 AM   #21
badger328
Hi All,
I'm having the same problem, my spare low pressure light has been on for 12 mths now and its driving me mad. The spare is correctly inflated and if i put the wheel anywhere on the car it works fine. No matter which wheel i put in the spare holder the evic always tells me that it is" spare low pressure" I asked a Jeep dealer and they want 98 per hr just to put it on the computer to tell me the problem and thats even without fixing it.Is there anyway to reset it myself. Thx
Also the alloy wheel sensor type tend to snap off at the valve with age and corrosion, the last time mine broke off about 2 yrs ago, i replaced the valve with a standard rubber one from the tyre dealers and cut the valve off the sensor and glued/polybonded the sensor to the inside of the wheel rim before the tyre was put back on, this saved me 70 because the tyre pressure is monitored by the tiny hole in the sensor and not by the valve. So if it breaks dont throw it away and buy new just do as i did. Thx
badger328 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 02:48 PM   #22
edmonds15
Can someone help me with my problem? My valve stem broke on my rear driver's side tire. I don't have the money to relace it right now, so I had them switch my spare with the tire that has the broken stem. My system is still giving me the reading for the one that has now become my spare. How do I get it to read the tire that I am driving with now?
edmonds15 is offline   Reply With Quote Quick reply to this message
