Almost time to lift and rebuild the fron suspension, whole control arms or just balls - JeepForum.com
post #1 of 5 Old 10-23-2013, 08:53 AM Thread Starter
deputyjason
Looking at Rock Auto, I can get Raybestos Professional grade upper and lower control arm assemblies for around $400. I can just get the same ball joints for around $100.
I have the big C clamp style ball joint tool, so thats not an issue. I will be in there installing new struts and lifting it 2 in so everything will already be apart.
Which is the better option?
deputyjason is offline
post #2 of 5 Old 10-23-2013, 09:41 AM
caulk04
2008 WK
I've not done any suspension service on the WK yet, so I'm not totally familiar with it...however.
The upper arm should include new bushings as well which is never a bad idea. The lower should include one of the bushings if bought as an assembly, if I recall correctly.
If your bushings are in good shape, I would just do the ball joints and save that coin. But by the time you factor in bushing cost you're possibly further ahead to do it all together now and save the labor of replacing bushings separately.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 5 Old 10-23-2013, 11:56 AM
Jeepforthewin
2010 JK Wrangler
If your control arms are fine I wouldn't mess with them unless you plan to beat them up offroad. If you do then I would go with JBA UCA's since they are beefier than stock. Havnt heard of the brand of UCA and LCA your looking at.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 5 Old 10-25-2013, 05:19 PM Thread Starter
deputyjason
I was qouting stock replacement part prices from Rock Auto.
post #5 of 5 Old 10-26-2013, 10:22 AM
JKM
2005 WK
I would recommend going to full replacement control arms are they include all new bushings. While they may be OK now, they may fail in the future and replacing the assembly now avoids dealing with it in the future.
The other thing, many here have had problems removing the lower strut bolt from the LCA. Some have had to cut the but and destroy the bushing in the LCA. Going with new LCA you can torch out the old bushing in the old LCA.
JKM is offline
