All gears on dash circled? - JeepForum.com
post #1 of 5 Old 12-24-2013, 12:08 PM Thread Starter
Mustang415
I've been having all the gears on the dash circled. It doesn't happen all the time. I also had the check engine light come on and I didn't get a chance to check the codes. I found out with my 07 jeep grand cherokee v6 that u can just turn the key once and it will start without you holding the key there but once te gears are circled I have to hold it there manually. Is this a module going bad need some help thanks!
Mustang415 is offline
post #2 of 5 Old 12-24-2013, 12:17 PM
sickchilly
2010 WK
Most likely the transmission control module contacts are dirty/corroded. Try cleaning before replacing:
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #3 of 5 Old 12-24-2013, 12:30 PM Thread Starter
Mustang415
Thanks a lot I think this Maybe my problem because I noticed it shifting differently lately but I bought a warrenty on the jeep so I might just take it back and have them fix it.
post #4 of 5 Old 12-30-2013, 01:11 PM Thread Starter
Mustang415
I got the code check and it said transmission control unit. My powertrain warrenty said they won't cover it because it's not inside the transmission. Is it bad to drive with it going out it's not over reving or anything I just don't have money to afford the unit right now
post #5 of 5 Old 12-30-2013, 03:04 PM
deputyjason
I had the same problem that happened intermittently. I wouldn't wait. I put it off, and my transmission blew so hard it cracked the pan and ruined the case(no core).
Dorman makes one that I got for $269 on Amazon and it works perfectly.
deputyjason is offline
