All dash functions shut off with engine running - JeepForum.com
post #1 of 11 Old 04-13-2013, 07:58 PM Thread Starter
afhanson72
I drove down the street today and as I pulled into a parking lot all my dash functions(ac,radio,all lights, and gauges) shut off for about 3 seconds while the engine was running. It hasn't done it again all day. My battery and charging system test ok. I have a 05 WK with the 5.7L. I thought I remembered reading this happening to someone else but I searched and could not find any posts.
Anyone ever have this issue?
Al
94 YJ - Plenty of mods
afhanson72 is offline
post #2 of 11 Old 04-13-2013, 08:31 PM
gamma500
2015 WK
Sounds like the ignition switch/module right behind the key cylinder has joined the ranks of the soon-to-be-dead ! A Search for "ignition switch" will bring up the DIY procedure if interested.
gamma500 is offline
post #3 of 11 Old 04-13-2013, 08:43 PM Thread Starter
afhanson72
Awesome, thanks. I will check it out.
Al
post #4 of 11 Old 04-13-2013, 08:56 PM
gamma500
2015 WK
Just make sure your battery isn't also on its last legs and low on volts which can mimic the ignition switch failure. The heater fan should also quit if it is the ign. switch.
http://www.jeepforum.com/forum/f67/t...t-you-1453946/
gamma500 is offline
post #5 of 11 Old 04-13-2013, 09:19 PM Thread Starter
afhanson72
Batt is good. Fan did quit also.
Al
post #6 of 11 Old 04-13-2013, 09:26 PM
gamma500
2015 WK
http://www.**********.org/f5/help-re...ch-9891-2.html (may delete www.j**pgar*ge.org) **= ee *= a
If heater fan dies than it is definitely the ign. switch and not the multifunction left stalk. You want the new ign. switch..$50 or so, some cheaper if you look, not the ignition switch holder with key/cylinder ($180). The above link gives a look at how to get at it a bit... Download the Jeep PDF Manual for free to see the instructions better..Section 8I-page 36. Good luck.
gamma500 is offline
post #7 of 11 Old 04-13-2013, 09:43 PM Thread Starter
afhanson72
OK, thanks for your help!
Al
post #8 of 11 Old 04-13-2013, 09:45 PM
gamma500
2015 WK
Hope it works out...easier than my swapping out the transmission on my wife's 05 WK !
gamma500 is offline
post #9 of 11 Old 04-13-2013, 11:04 PM Thread Starter
afhanson72
Will be a lot easier than swapping out the HVAC distribution unit on my WK that I just did a few months ago. Talk about tearing the whole dash apart!
Al
post #10 of 11 Old 04-14-2013, 05:49 AM
gamma500
2015 WK
That's for sure...
gamma500 is offline
post #11 of 11 Old 06-28-2014, 10:41 AM Thread Starter
afhanson72
This problem finally reared it's ugly head again this week. I went to the Jeep dealer and bought the ignition switch. Not the keyhole and tumblers but the electric switch as described in the link above. It was a 15 minute swap out. So far so good, but we will see if the problem presents itself again.
Al
