for all the budget boost guys with 285s.... - Page 3 - JeepForum.com
post #31 of 42 Old 05-03-2012, 06:45 PM
andrew44
2005 WK
Originally Posted by AJeepZJ View Post
No spacers up front, I bought some but ended up not installing them.
Sway bars are connected, MLL's are installed. I'm not sure what you mean. the rear is on flat ground. But, the front driver-side wheel is going up the hill, hence the compression on rear passenger-side.
I see it. was just making a stupid observation that it looked like you were leaning sideways on flat ground lol
05 WK GC Limited 4.7L Nitto trail grapplers 285/70/17 RR 2.25" Bilstien Shocks. RC 1.5" Wheel Spacers. deck and 10" sub. HID8000 Head lights. Superchips Flash Paq. 22" stainless Magnaflow muffler.
andrew44 is offline
post #32 of 42 Old 05-04-2012, 09:42 AM
andrew44
2005 WK
Originally Posted by JRLT View Post
No pics.
So first i did the front pinch weld mod. i heat gunned the plastic down as far as i could. but it still wasnt enough for the 285's! so i did this......marked with yellow marker where i want to cut.. then took portable air grinder wheel and went to town....cut out a piece that looks like this.....
[IMG][/IMG]
Then i took a sheet metal screw (black)and screwed up the back inner side of the plastic to the fire wall. did it up high enough to not catch tire by accident. and sunk it into the plastic to it was flush. Then took rubber in a can spray and shoot the exposed frame (in my case the silver paint showing where you cut) make sure its even and take a piece of card board to scoop up the drips.. when its done you can hardley even tell i cut it.......
[IMG][/IMG]
andrew44 is offline
post #33 of 42 Old 05-07-2012, 10:05 AM
ryanlamb00
2005 WK
Could you try and get some more pictures including one that's of the face of the wheel
ryanlamb00 is offline
post #34 of 42 Old 06-25-2012, 10:11 AM
paroxysym
2007 WK
bump, just saw this topic after making a similar one... i see theres at least 3 rigs on here with BB and 285s. liking that squatty look alot- nice work andrew.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #35 of 42 Old 06-25-2012, 10:40 AM
Piepenbrok420
o| | | | | | | |o
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #36 of 42 Old 06-25-2012, 10:49 AM
paroxysym
2007 WK
do you have any shots fron the front?
OEM+
post #37 of 42 Old 06-25-2012, 10:58 AM
Piepenbrok420
ill go take a couple now
o| | | | | | | |o
post #38 of 42 Old 06-25-2012, 11:01 AM
Piepenbrok420
o| | | | | | | |o
post #39 of 42 Old 06-25-2012, 04:33 PM
kdawgFL
2005 WK
anyone think i can fit some 285's w only 1'' wheel spacer, i was also thinkn 285 65's.. 32s. given i do pinch mod. plus mll's
kdawgFL is offline
post #40 of 42 Old 06-25-2012, 05:47 PM
Piepenbrok420
you would still run into the problem of width with the 285/65's if there's any problem at all, as long as you dont full lock the wheel all the time and your alignment is good i think you'd be good to go.
o| | | | | | | |o
post #41 of 42 Old 06-25-2012, 06:30 PM
S1L3NT_WH33L3R
2005 WK
Ome+285s
That's what youre looking for correct?
ForumRunner_20120625_182712.jpg   ForumRunner_20120625_182759.jpg   ForumRunner_20120625_182849.jpg   ForumRunner_20120625_182908.jpg
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #42 of 42 Old 10-20-2013, 01:35 PM
05wkmoneypit
2005 WK
Hey guys im new to jeeps. I have a 05 limited 4.7. With the stock chrome rims. I just ordered a rro 2.25 lift. Will i be able to fit 285s on the stock rim? And if so will i still be able to go offroading without scraping out my fender walls? If im on an angle or rocks? Or blasting through some mud? I searched some threads but couldnt find the answers im looking for thanks!
05wkmoneypit is offline
Budget Boost VolcomPunk ZJ Grand Cherokee Forum 62 11-14-2011 08:07 PM
budget boost q's steve L. ZJ Grand Cherokee Forum 6 12-02-2008 10:46 AM
2" budget boost on a budget lambar ZJ Grand Cherokee Forum 17 05-07-2008 09:38 PM
budget boost goldj ZJ Grand Cherokee Forum 8 11-03-2007 08:53 AM
budget boost or not john1998 ZJ Grand Cherokee Forum 19 12-15-2005 04:58 PM
