Alignment trouble, JBA UCA and OME HD - JeepForum.com
post #1 of 14 Old 12-24-2013, 04:37 PM Thread Starter
mykdee311
2005 WK
just got some new tires on (255/75r17 Nitto Trail Grapplers), and replaced the Tie-Rod Ends myself.
immediately took it in to get an alignment, before they closed on Christmas Eve. they worked on it for 2 hours, and said they got it as close as they could. they said that the lift didn't have enough adjustment to get it any better, which I can understand not having any upper adjustments.
I'm just frustrated because that was the point of buying the Upper Control Arms from JBA, for a "factory front end alignment...on jeeps with a lift" as his website claims.
fortunately they got the toe in check. however the right camber is -1.5*. while the left camber is 0.0.
here is the info:
Camber:
R 0.0, L -1.5
Caster:
R 3.3, L 3.0
Toe:
R 0.07, L 0.06
Total Toe: 0.13
Steer Ahead: .01
what are your thoughts? is this the shops fault, or the jeeps setup?
I have had it aligned once before with the same setup, but my wife took it in, and I honestly didn't look at the printout.
05 WK Limited, QDII, Hemi, Superchip, OME HD Lift, JBA UCA & disconnects, 4xGuard (Belly, Sliders, Rear Sliders, Diff), 255/75R17 on Moab's w/ 1.5" Spacer, Thule M.O.A.B. Basket
03 3500 Cummins, 79 Mustang 2.5T Stroker, 63 F250 428 4x4
mykdee311 is offline
post #2 of 14 Old 12-24-2013, 04:42 PM
atarijedi
2008 WK
here is the info:
Camber:
R 0.0, L -1.5
Caster:
R 3.3, L 3.0
Toe:
R 0.07, L 0.06
Total Toe: 0.13
Steer Ahead: .01
Maybe they will have the previous alignment on file, and can reference it?
atarijedi is offline
post #3 of 14 Old 12-24-2013, 04:49 PM Thread Starter
mykdee311
2005 WK
its a different shop than last time. I am in the process of going thru some files to see if I can find the other printout, I feel like I got ripped off.
post #4 of 14 Old 12-24-2013, 11:19 PM
ttusqrl
2005 WK
Did they adjust from just the UCAs or did they move the LCAs as well?
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #5 of 14 Old 12-25-2013, 04:06 AM
Valpacer
2007 WK
Camber is adjusted on the LCA's in a WK.
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #6 of 14 Old 12-25-2013, 11:04 AM Thread Starter
mykdee311
2005 WK
so nobody else with JBA UCA has any issues getting their jeep aligned?
since they said there wasn't enough adjustment because of the lift, i assumed that the LCA didn't have enough adjustment..due to the uppers position. i guess the shop isn't competent, i asked him why there was enough adjustment to get the one side aligned but not the other..he didn't know.
post #7 of 14 Old 12-25-2013, 03:34 PM
SSF556
2008 WK
seek out a Firestone shop....the one here treats me well..
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #8 of 14 Old 12-25-2013, 04:00 PM
tjkj2002
2002 KJ Liberty
You either got something bent(what are the SAI angles?) or the cradle got shifted to one side a little.
Adding JBA's UCA's just helps get a better alignment and they(and no one else for that matter) can account for any vehicle damage.The smallest hits can shift/bent things real easy.
tjkj2002 is offline
post #9 of 14 Old 12-26-2013, 08:34 PM Thread Starter
mykdee311
2005 WK
hmm i might have to check into SAI angle, i didn't know that existed. everything looks normal to the eyes, but i'll try to measure both sides. never checked that before though
post #10 of 14 Old 12-26-2013, 08:37 PM
tjkj2002
2002 KJ Liberty
You need a alignment rack to measure the SAI angle.
tjkj2002 is offline
post #11 of 14 Old 12-26-2013, 11:55 PM
Valpacer
2007 WK
Honestly there is quite a lot of range in the LCA for alignment, ive beaten my suspension over so much and can still get it aligned and drive straight.
Need to find a good reliable shop, thats the main battle.
Valpacer is offline
post #12 of 14 Old 12-27-2013, 01:24 PM Thread Starter
mykdee311
2005 WK
i've rock crawled mine quite a bit, but never really felt like i was beating it up too bad. I've seen most of your videos Val, if your jeep still aligns straight, mine should too haha. i think it was the shop, its only about a month old and i have never been there before. it was christmas eve also, they were probably being lazy. waste of $70.
post #13 of 14 Old 12-27-2013, 02:52 PM
ttusqrl
2005 WK
Firestone seems to be the only name brand shop that knows how to do it without telling them.
That said, I use NTB since I have a five year alignment package there.
EDIT: I'm sitting at NTB now getting a rotate and balance
ttusqrl is offline
post #14 of 14 Old 12-27-2013, 08:15 PM
robpp
some of them dont realize there is a bit of lower adjustment. the hole is slotted and it slides. not a ton but SOME.
and lots of shops cant deal/
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
