Alarm remotes - JeepForum.com
post #1 of 2 Old 12-08-2007, 09:15 AM Thread Starter
brewerdude
Alarm remotes
Both of the alarm remotes attached to the keys of my '05 GC stopped working. First thing I did to try to resolve this was to replace the batteries. Turns out the little bracket that holds the battery against the circuit board had broken off (on both). Since I have the extended warranty (at 50K mi), I went down to the dealership to get these both replaced. Come to find out that: a. these aren't covered under the extended warranty, b. they want $250 per key to replace! Ouch!!
I'm going to try to solder the bracket back into place myself first before I plunk down $500 for a set of keys. Anyone else have an experience like this? I find it very odd that both keys failed in the same way and that $250 for a replacement key is a bit excessive...
brewerdude is offline
post #2 of 2 Old 12-10-2007, 02:07 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
$250 is way too much. I got mine for $120 plus $20 cutting/programming fee. Still too much for a key IMO. See if you can buy a blank off of ebay then just bring it to the stealer to cut/program.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
WJ keys and remotes jeeplover93 ZJ Grand Cherokee Forum 8 06-22-2009 10:31 PM
Programming 98 ZJ Remotes NoreasterPlus2 ZJ Grand Cherokee Forum 1 06-02-2008 01:58 AM
Remotes cpc28655 ZJ Grand Cherokee Forum 3 09-24-2007 08:32 PM
Keyless remotes one and two bsd083 ZJ Grand Cherokee Forum 3 04-21-2006 09:00 AM
Keyless Remotes jim2527 ZJ Grand Cherokee Forum 15 11-11-2004 04:00 PM
