Airbag warning light - JeepForum.com
post #1 of 19 Old 04-24-2012, 03:24 PM Thread Starter
hsucram
Hello all, I just bought a 2008 Jeep Commander about 1 1/2 months ago, my airbag warning light has been coming on like clockwork once a week for the last two weeks, it will stay on for a out 5-10 seconds & then go out, I don't know if it's a short circuit or a bad sensor or what, it seems like whenever it comes on I'll have some groceries in the passenger seat, I'm not quite sure why this is happening, does anyone have any ideas or suggestions?
hsucram is offline
post #2 of 19 Old 04-25-2012, 06:12 AM
muddy93
1987 FSJ Wagoneer
not in the right section, this is the full size jeep (FSJ) section, and none of those ever had air bags.
Anyway, your commander most likely has a weight sensor in the passanger seat, which de-activates the passanger air bag when there is less than a specific amount of weight in the seat. There may be an issue with the sensor, or the amount of "groceries" could be close to the "cut off weight" for the sensor, so the computer is deactivating the bag, which is why the light is coming on.
Try not puting your groceries in the passanger seat, and see if the light still comes on.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 19 Old 04-25-2012, 07:28 AM
BJ's Off-Road
1979 FSJ Cherokee
The Commander section is here:
http://www.jeepforum.com/forum/f67/
www.bjsoffroad.com
BJ's Off-Road is offline
post #4 of 19 Old 04-27-2012, 06:22 AM Thread Starter
hsucram
Airbag light on
hsucram is offline
post #5 of 19 Old 04-27-2012, 06:26 AM Thread Starter
hsucram
Okay, thanks a lot, I took it to the dealer, they said I need a new driver's side seat belt buckle.
hsucram is offline
post #6 of 19 Old 04-27-2012, 06:31 AM
05WKinPA
2005 WK
It's normal. Its just the sensor in the passenger seat. It's working as designed.
Rocky Road & OME MD hybrid lift / AEV Pintlers / 32" BFG Mud Terrains / Four X Doctor rear diff guard / JBA UCA's / 4XGuard Belly Skid / Stillen cross drilled rotors
05WKinPA is offline
post #7 of 19 Old 04-27-2012, 06:57 AM
BonesWK
2006 WK
X2
And its a bit annoying... so I put all my crap in the back seat.
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #8 of 19 Old 04-27-2012, 01:38 PM Thread Starter
hsucram
Okay, I went to the Jeep dealer so they could give a diagnostic & they said I need a new drivers side seat belt buckle........
hsucram is offline
post #9 of 19 Old 04-27-2012, 06:23 PM
modernblueWK
Is it the red airbag light on the instrument cluster? Or the "Passenger airbag on" light? If the latter its the weight sensor but those are usually set at 90ish pounds minimum. If its the red light in the cluster then there is a problem somewhere. I had the light on solid a few weeks ago. A yellow plug right in front under the passenger seat was loosely connected. Re clicked it tight and problem solved.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #10 of 19 Old 04-27-2012, 08:44 PM
JRLT
2010 WK
Seat belt buckle? Are you sure they didn't say windshield wiper? Either way, it doesn't make very much sense.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #11 of 19 Old 04-28-2012, 07:04 AM
Carn75
2014 JK Wrangler
Really people .....TROLL!!!
98' TJ Sport-Modded SOLD :-(
14' JKU Altitude Edt.-Metal Cloak 2.5, Jcr Offroad,35s,etc
Carn75 is offline
post #12 of 19 Old 04-28-2012, 08:27 AM
modernblueWK
Who you callin a troll?
SOLD 2008 WK 4.7 V8
post #13 of 19 Old 04-28-2012, 08:56 AM
Carn75
2014 JK Wrangler
Look at the OP,look at his response...who do you think I'm calling a Troll?
Carn75 is offline
post #14 of 19 Old 04-28-2012, 11:06 AM
modernblueWK
Im not sure i would call him a troll, maybe just ininformed and at the mercy of a terrible dealership. There are alot of those around!
SOLD 2008 WK 4.7 V8
post #15 of 19 Old 04-28-2012, 12:08 PM
BonesWK
2006 WK
I know I'm one... I don't think its a seatbelt issue.
Why would a bad seatbelt cause a airbag light?
Ryan
BonesWK is offline
