08-15-2012, 07:37 PM
#1
had my 2006 grand cherokee detailed and now the air bag light is on. How do I get it off?
08-15-2012, 07:38 PM
#2
Car ram rod
wrong section.
'12 Laredo V6 ORA1|Terra Grappler 265-70-17|MB TKO 17x8.5 0 offset|Silverstar lows|Mopar Front and Rear WK2 slush Mats|RRO 2.5" lift
BWoody extended sway bar links|K&N 77 Series Intake|Gibson Exhaust
08-15-2012, 07:51 PM
#3
Originally Posted by Jackal01
wrong section.
where do I post this?
08-15-2012, 08:41 PM
#4
Check all the connectors under the front seats. They may have popped one loose with an aggressive vacuum extension.
And it looks like the right section to me? 2006 gc=wk ??
2008 wk 4.7 v8 Laredo X QTII 245/70-17 at2
Blue WK club #4
2013 HEMI Durango Awd Crew.
08-15-2012, 09:06 PM
#5
My airbag light goes on as well but everything looks connected when i checked under the seat. I initially checked under the seat, because my car thinks someone is always sitting in the passengers seat. Not to jack you thread but i would also know if anyone knows what could be wrong.
08-15-2012, 09:08 PM
#6
X2. Double check fuses etc. More then likely its the connectors though considering they probably rammed a vacuum hose under it.
And your in the correct section..
Dodge Dakota SXT 3.7L _sold_
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Fastman 81mm TB, K&N Full CAI, Diablo Custom 93
Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
08-16-2012, 04:10 AM
#7
USAF
I had this problem in my 08 Avenger. I took a zip tie and tied the connector under the passenger seat as tight as I could get it. Solved the problem. My wife drives it now and she has never seen the light.
Upgraded to 430N RHB MyGig }{ 3.6L V6 Laredo X }{ Off-Road Adventure I }{ Trail Rated }{ QTII }{ Selec-Terrain }{ OEM Skid Plate Group }{ Flex Fuel
08-16-2012, 06:48 AM
#8
Car ram rod
Already moved. Should have been more clear with that post, sorry. It was in Wk2.
Sent from my HTC Thunderbolt using JeepForum
08-16-2012, 07:35 AM
#9
USAF
Is there a way to close this thread since it was moved?
08-16-2012, 10:58 AM
#10
What I was told (because mine does the same thing) is that something may have gotten under the seat or pushed up on the sensor in the seat that uncalibrated the sensor. It may need to be recalibrated by the dealer..
2005 WK Limited
4.7L w/Quadra-Drive II
<img src="http://i1262.photobucket.com/albums/ii602/TanagrineMilk17/9aca3e0b.jpg" width="120" height="90"></img>
08-17-2012, 05:56 AM
#11
hate to pay the $100.00 for them to do something that could be very simple to fix.
08-19-2012, 06:39 AM
#12
Car ram rod
I assume because it was still in the WK2 section? If that was the case (cannot remember what I did) a thread can have an expiring redirect link anywhere from 1 hour to 10 years, or No Redirect or Perm. redirect. I will usually do 1 day so if the person wants to find it by going back to the [wrong] section they can. After that the link goes away and they can find it in their My Threads link.
