AEV/Superlift EGR Module - JeepForum.com
post #1 of 8 Old 04-04-2013, 11:49 AM Thread Starter
XK1982
2006 XK Commander
For those that have the AEV/Superlift Recalibration Module, does it work well for you? It says corrects most ESP issues at low speeds, how does it work when cornering at higher speeds? Do you think it's worth it? Also any tips on where I could find one for an 06' XK? Everywhere is on backorder.
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #2 of 8 Old 04-09-2013, 05:18 PM
JeepinShep
2007 WK
Related question - the EGR module has a recalibration mode where you can reset the speedometer and odometer for larger tires. Instructions state you plug it into OBDII, let the relays chatter away, and then it's all set.. Plugging it inline under the dash is for the actual ESP issues when lifted and changing the geometry ...
My speedometer changed not at all after following the instructions. I've emailed them twice, tried calling a couple of times (got a discontinued service message).. Anyone out there with experience on this thing know what I'm supposed to be doing that I'm not?
2007 WK Limited, Red Rock Crystal, 3.0L CRD, QD-II. OME HD lift. 255x75x17s. Pinchweld mod. 1.5" Alloy hub-centric spacers. F/R Stillen rotors and pads. 4xG rear diff guard and belly armor. Tuned by Green Diesel.
Originally Posted by bhoch
...you never, ever, skimp on suspension and tires as they will save your *** when you do something stupid - and .. you *will* do something stupid.
Originally Posted by DeansWings
Rock crawling is a whole 'nother animal. To me, the off-camber low rpm negotiation of lines provides a different type of adrenaline than plowing through mud. It's terrifying at times, but the pride of looking back at what you just climbed over is what is addictive.
JeepinShep is offline
post #3 of 8 Old 04-09-2013, 06:12 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well I have been running a SL without the EGR module for over a year now and only just got the EGR a week ago. I have made it a habit to hit the ESP button upon start up every time. That method worked great for the past year, but I was still getting ESP activation fairly often. I had to learn how to drive the Jeep to minimize activation. As much as I could have continued driving without the EGR I have been trying to fix and do things to the Jeep so that when I deploy my wife has little to no issues with it. So I bought the EGR from Kolak for a great price, but had to wait until AVE got around to making more of them. I just got it a week ago, so chances are he can probably still get one for you. I have enjoyed driving with it and although I have had ESP activate a couple of time, it isn't nearly as often as it was before!
Omelet is offline
post #4 of 8 Old 04-10-2013, 06:28 AM Thread Starter
XK1982
2006 XK Commander
Thanks for the info! I'll have to check with Kolak as well to see if he can get me one for my 06. In the same boat, when my girlfriend or parents need to use the Jeep I'd prefer to have the module installed so the ESP doesn't start getting all crazy while their driving. Plus I like the idea of being able to adjust the shift points for the larger tires as well as (hopefully) correcting the speedometer.
XK1982 is offline
post #5 of 8 Old 07-11-2013, 11:18 AM Thread Starter
XK1982
2006 XK Commander
Follow-up on the AEV Module. I installed it, adjusted tire size, shift points and speedometer. Everything worked great for a week or two. I didn't even have to press and hold the esp button. Then all of the sudden for no reason the next time I went to drive the jeep the esp starting activating even with the slightest turns and slow speeds. It was like I didn't have the module at all. Has this happend to anyone else? Seems like the module just stopped working. Now I'm hitting my esp button again haha
XK1982 is offline
post #6 of 8 Old 07-11-2013, 11:42 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Did one of the plugs come loose?
Omelet is offline
post #7 of 8 Old 07-12-2013, 06:00 AM Thread Starter
XK1982
2006 XK Commander
I guess it's possible but I haven't checked yet. I'll keep you posted on what I find this weekend!
XK1982 is offline
post #8 of 8 Old 11-26-2013, 09:56 PM
RthrBN4LO
2006 WK
Question: How is the ESP still activating when you turned it off every time? Did Jeep program it so that ESP never really turns off completely? I'm wondering what effect this has over the long term when wheeling or otherwise when ESP causes unsettling grinding noises from the front end. Any reason to worry about premature failure or worn parts from this?
RthrBN4LO is offline
