09-14-2009, 02:28 PM
#1
Advise a good 60k Tuneup on a 5.7l
Hey guys, my friend just rolled up on the 60k mile mark and he wants to do the proper tune-up/service procedure. Its an '05 WK Limited, every option available, and the 5.7 Hemi. In addition to getting the FL Axle boot replaced (it has a tear in it), we're forming a list of things to do.
He bought it used at 54k. Assume the worst and assume that the only regular maintenance its had is oil change, tire rotation, etc.
Oil is fine until 63k and theres aftermarket cold air intake so doesnt need replacement air filter. I think the engine runs great, but we figure might as well keep it well maintained for maximum performance, efficiency, life, etc
So what would you advise for a proper tune-up?
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
09-14-2009, 05:07 PM
#2
New plugs? Clean the throttle body. Maybe replace fuel filter
06 WK Limited 4x4 Racing Solutions 6.4L 392 Stroker HEMI - 2" Daystar / 255-75-17 BFG MT's / SpiderTrax 1.5" / SRT8 Exhaust / K&N Intake / HID Headlights and Fogs / Alto Red Eagle Clutch Packs / Transgo Shift Kit / Diablo Trinity / Bilstein Shocks / Rear SRT Sway / Deeza Front End Links
09-14-2009, 05:36 PM
#3
Flush diffs, tranny, tcase, radiator, check pads, turn rotors, check bushings, new shocks.........I'm rambling.
Justin
2013 Wrangler Sport
Chattanooga, TN
09-14-2009, 06:34 PM
#4
We tried doing the TB ourselves but ran into the issue that the butterfly valve is electrically controlled, therefore, you can't really get it open and spray/scrub the sides well
I think the tranny fluid flush would be a good thing...
Build Thread
RIT Offroaders
Matt
09-14-2009, 07:42 PM
#5
I'm coming up on this same service time frame, I would love to hear back from you on any pointers or tips that may be helpful.
Justin
2013 Wrangler Sport
Chattanooga, TN
09-17-2009, 10:32 AM
#6
I'm also curious about the upkeep of these motors...
Wife's "New" Car- '06 Commander Limited 4.7L- 95k
Wife's "Old" Car- '03 Liberty Limited- 151k
'97 Dodge Ram 1500 4x4
'06 Mustang GT Windveil Blue- Borla Stingers, MGW Shifter, Intake/Tune, GT500 wheels/tires
'93 Mustang LX Notch- 144k, Saleen Speedline Wheels
09-17-2009, 11:26 AM
#7
For the engine, new plugs. There's 16 of them so it can take a little while. Get the copper ones.
New air filter if you need one.
For the '05s check and maybe replace the Ignition Cables
Check and maybe replace the Serpentine Belt
Transfer case fluid change.
Differentials if you have Quadra-Drive.
Check the bushings and maybe transmission fluid and filter change. Not flushed.
PCV valve is also called for a swap at this mileage.
Jeep Grand Cherokee WK - Maintenance information and schedules
255/75-17 BF Goodrich Mud Terrain TA KMs, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
09-17-2009, 02:21 PM
#8
Good news and bad news...
bad news is I didn't get to do any of this myself, I was kinda lookin forward to working on it. Haha instead (which is also good news) he took the easy yet expensive route and sent it into Jeep for the 60k tuneup. Looks like its going to run him around $1100+ but hes got the money so I didn't protest. I will post up a list of all the stuff they did but so far I can confirm they did pcv valve, plugs, wires, transmission fluid change, coolant flush, diff fluid flush (he has QD) and he also got the axle boot repaired and the trim re-adhered (the foam underneath came off in the car wash so now they rattle with bass from the stereo)
Build Thread
RIT Offroaders
Matt
09-17-2009, 06:45 PM
#9
Pricey but I think he did the right thing. Now he knows all has been taken care of and that will remove any worry about the maintenance from the previous owner. Should be good to go now.
Oldmac1
11 GC Overland
12 Liberty
08 Rubicon Unlimited
09-17-2009, 08:53 PM
#10
60K service is around the corner (probably in November) for me.. I'll be doing the following:
- Oil and filter change (M1 5W20 + filter)
- Front and rear diff fluid change (M1 75W140 + Mopar limited slip additive)
- Transfer case fluid change (Mopar TC fluid)
- Transmission fluid and filter change (Valvoline Synthetic ATF+4)
- 16 spark plugs (Champion Copper)
- New PCV valve
- Inspect ignition cables and replace if necessary
- Inspect serpentine belt and replace if necessary
- Check all other fluids (coolant, brake, power steering)
- Check brake pads/rotors for even wear
-Frank the Tank-
-2005 Jeep Grand Cherokee Limited-
- 5.7L HEMI/QDII/Superchips/AEM Brute Force/MBRP/RRO/Bilsteins/32s -
