Advice On Getting Tree Lines Out of Paint? - JeepForum.com
post #1 of 6 Old 10-19-2013, 01:43 PM Thread Starter
redshift88
2008 WK
So,
It seems I have the worst possible color for an off-road vehicle, Black. I went wheeling with some friends in the woods of Pennsylvania and ended up pushing a lot of branches with my WK. The wranglers didn't have this problem as they have the cross section of a small cat.
Anyways, last time, I was able to get 95% of the lines out with a liquid polishing compound and some wax. For the deeper wounds, I tried some rougher polishing compound, but just ended up with swirl marks to accent the scratches.
I've been told that using a detergent like dawn will take off the wax, and make for a better polishing surface, but before I try "home concoctions," I'd like to hear your thoughts.
Don't worry, I am somewhat proud of my tree lines.
See below for a picture. The picture looks 100x worse than it actually is, as most of those lines are just moved dust and came out in the rain.
For fun:
redshift88 is offline
post #2 of 6 Old 10-19-2013, 01:56 PM
Jeepforthewin
2010 JK Wrangler
Those aren't scratches they are custom pin striping! Wear them with pride!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 6 Old 10-20-2013, 08:56 AM
colinzj
2006 WK
Wax isn't film-building in any meaningful way. Car wash will serve you just as well as Dawn for assessing and preparing the surface (and won't chalk your plastics and rubbers). Between the solvents and the mechanical action in a polish or compound, wax just isn't a concern.
For the easy scratches, it sounds like you've got it dialed in. Keep that up.
For the deeper ones, where most people go wrong is in going too aggressive with their compounds. What did you use? A traditional aggressive compound is designed to cut hard and be polished back out with a series of less aggressive compounds. Most people are oblivious to this and also think their paint damage is worse than it is, so they reach for some totally inappropriate product and end up with the paint looking worse than it did. Meguiar's has for years promoted the mantra of "Use the least aggressive product that gets the result." Whatever brand of products you use, embrace it. Live it.
With swirl marks specifically, it could also be a matter of applicator (terrycloth, for example, would be the wrong material—you want a foam pad) or application technique.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #4 of 6 Old 10-20-2013, 09:38 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ This..........
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #5 of 6 Old 10-20-2013, 11:18 AM
bhawks28
2014 JK Wrangler
haha yeah I have those all over my WK. I was really worried about it the first time it happened, but I've got way bigger things to worry about. Now I have them all over and I couldn't care any less!
2014 JKU Rubicon
bhawks28 is offline
post #6 of 6 Old 10-20-2013, 05:02 PM Thread Starter
redshift88
2008 WK
I went with a heavier duty compound, turtle wax brand. So, to get the swirls out, it sounds like I have to step up grit in stages to get it back to no swirls? I think that was my mistake.
I bought a set of foam applicators, so I think I went in the right direction there.
Thanks for the advice, folks! I am proud of my scratches! The folks at work think I'm crazy. However, I will continue to try an polish them out.
