08-04-2012, 11:41 AM
#1
Adding trailer hitch receiver
Hey guys,
So i have a 06 WK without the trailer hitch receiver, and was wondering if I can add one to it. I know that justforjeeps.com sells the receivers but does that mean you have to cut the stock bumper or would you have to buy a whole new bumper?
Thanks for the help as always!
08-04-2012, 12:58 PM
#2
I bought mine for 152 with the harness and cover from thehitchstore.com. Did not have to cut anything and looks decent. Took 20 min to install, 30 with wiring.
2008 Red Rock Crystal Pearl CRD || OME HD | 285/70/17 Goodyear Silent Armor | Cobra NW 29 Black Edition | Aspen Creek CB Mount & Switch Panel | OTRATTW Switches | Rola Rack | KC Long Range Hi-Lighters
08-04-2012, 04:16 PM
#3
X2 Etrailer has great deals as well.
08-04-2012, 05:55 PM
#4
Here's my Curt hitch, it doesn't look quite as nice as the OEM style but it was cheap and easy to install. No cutting or drilling required, plus the lower mounting location works out perfect for lifted WK's.
Silver '06 Laredo 3.7L
- 2" RC lift, 1.5" RC Spacers, 58643 MLL's, !Pinch Weld, Spyder Bull Bar, 130w KC Daylighters, Spyder LED Tails, Taillight Guards, Silverstar ZXE's, Interior LEDs, Hypertech Max Energy, Kenwood 6" DVD/NAV, 12" Audiobahn Sub
08-04-2012, 06:12 PM
#5
Thanks guys these help a lot, where did you get that curt hitch man?
06 WK | 3.7L | QT1 | Leather Interior | 2" Daystar Lift |Bilstein Shocks/Struts | 265/70/17 Treadwright Guard Dog MT | Pinch Weld Mod | Spidertrax 1.5" Spacers | Expanded Sheet Metal Grille | 15% Front Tint | 10% Entire Rear Tint | Spyder LED Tails | 7w Cree LED Reverse Lamps | Midland 1001 WLX CB | 3' Firestick | PA | Cargo LED Lights | iPhone Integration | Straight Pipe Exhaust | Solid Diff Cover | Shorty Antenna
#6
I'm using the same as Luck06, the height makes a normal 2" drop perfect at stock height and obviously lesser drops than oem hitch for lifted WKs.
08-04-2012, 06:19 PM
#7
Got mine from Amazon for around $100
08-05-2012, 09:12 AM
#8
Any links you guys could hook me up with? There's like 20 of them on amazon idk which one to buy.
08-05-2012, 10:21 AM
#9
Junior Member
'07 WK Overland Hemi - QDII - 4x Guard front skid - Volant CAI - Superchips - OME HD - 285/70R17 Duratracs - Spidertraxx - Gibson cat back - BT catch can
08-05-2012, 11:54 AM
#10
Thanks man thats a huge help, do you think I'm going to have to remove the rear bumper to bolt the hitch on?
08-05-2012, 04:38 PM
#11
The instructions said to but I just removed the 4 clips underneath and slid it in with no issues at all.
08-05-2012, 05:27 PM
#12
Yea I didnt have to remove the bumper. It seems like I might have had to drop the spare a bit though, can't remember.
08-05-2012, 05:31 PM
#13
As with Luck I did lower the spare as well. But Moreno because it let me use a ratchet rather than a wrench and I'm too lazy to spin a regular wrench that much plus it made wiring easier.
08-06-2012, 08:38 AM
#14
1998 Jeep Wrangler 2.5L Turbo @10psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 33s TSL Boggers with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
08-06-2012, 09:59 AM
#15
USAF
I also had the OEM hitch, removed the bumper for install. Bought the bezel kit and cut the bumper for the stock look. Took about 2 hrs, the only hard part (and nerve racking) was cutting. In the end it looked 100% stock just like it came with the hitch installed from the factory. I'd say a difficulty of 6-7 out of 10.
Go with the OEM, IMO it looks best.
Upgraded to 430N RHB MyGig }{ 3.6L V6 Laredo X }{ Off-Road Adventure I }{ Trail Rated }{ QTII }{ Selec-Terrain }{ OEM Skid Plate Group }{ Flex Fuel
