Adding Factory Tow wiring harness to 2wd v6 Commander - JeepForum.com
post #1 of 3 Old 09-04-2007, 11:23 AM Thread Starter
rstrickl
2007 XK Commander
Hi,
I'm getting the run around on the correct tow 7-way wiring harness fro a 2007 v6 2wd Commander. Originally sold p/n 82211150 which splices into Foward Control Module but does not use the tow relays for turn/stop but instead uses the Rear Left/Right trun signal control lines for turn/stop. Everything works except the problem is the turn signals on the commander do not light up during braking, even though they are behind the red tail light lens. I've noticed newer Grand cherokees whose tail lights work this way too. How can this tow harness be correct??? The other part number 82209766 use the tailight wiring to connect and uses the tow relays for turn/stop. I've been told that this is also only for 4wd and v8 Commanders. So I'm very confused and frustrated right now. Anyone know more about this?
rstrickl is offline
post #2 of 3 Old 09-04-2007, 07:35 PM
Radiac
Radiac's Avatar
Did you have the dealer activate the trailer lights? They need to do that before they will work, at least I had to on my '06.
His: 2006 Bright Silver Commander
Hers: 2004 Bright Silver Grand Cherokee Laredo
Radiac is offline
post #3 of 3 Old 09-04-2007, 09:15 PM Thread Starter
rstrickl
2007 XK Commander
Yep that would work if I could use the 2nd p/n 82209766 that uses the tow relays, then the dealer enables the relays via the star scan tool and life is good. I just looked tonite and the wires are missing to the rear left tail light that would allow connecting the tow relays via the supplied connector to the tow plug, so I can't use that p/n..darn it. I think on 2006 this was the only p/n but on 2007 they left off some wires on the 2wd v6 and you have to use the splice p/n 82211150. That still leaves me with this harness not working because of the rear turn lamps not coming on during braking.......
rstrickl is offline
(ZJ) Adding factory fog lights - how to ZJunk ZJ Grand Cherokee Forum 102 01-20-2015 11:33 PM
Adding a window antenna to the Commander DocUwe WK Grand Cherokee & XK Commander Forum 0 07-21-2009 12:45 AM
wiring harness / factory amp not2high ZJ Grand Cherokee Forum 4 07-14-2008 12:20 PM
Non Factory Tow Harness 4 My JEEP PresTx82 ZJ Grand Cherokee Forum 5 06-13-2007 02:50 PM
Wiring harness question ... 98 harness in 93?? mjessop23 ZJ Grand Cherokee Forum 1 05-24-2007 09:17 AM
