AC sucks, freon issue? - JeepForum.com
post #1 of 10 Old 08-16-2017, 12:21 PM Thread Starter
xjshellback
2008 with the 3.7
150K miles
just recently the ac has started become dry heat option.
sitting at idle, blows cold.
cruise control in the interstate, blows cold.
braking/slowing down, blows cold.
accelerating (hard or easy), blows hot.
speed constantly changing, blows hot.
thinking its time to get the freon re charged? any ideas?
i have played with the kit from the store and cant get any better results.
08 WK 2in lift 265/70/17 3.7L
10 JKU Sahara 3in lift 35X12.5R18
xjshellback is offline
post #2 of 10 Old 08-16-2017, 03:14 PM
RCS1300
2005 WK
If it blows cold, it is probably not the freon. If constantly changing speed creates the hot air issue I would look at the compressor clutch and/or the serpentine belt.
RCS1300 is offline
post #3 of 10 Old 08-16-2017, 04:56 PM
moonvan
2008 WK
I would guess A/C clutch is slipping as well or worst case the pump is wearing out and causing drag.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #4 of 10 Old 08-16-2017, 11:28 PM
azzkicker
2007 WK
Belt or tensioner. The Freon has no idea you're accelerating, but the belt sure does.
Clean the pulleys really well with brake cleaner or alcohol, and probably replace the tensioner at the same time. You could try just the belt first if you're on a tight budget.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is online now
post #5 of 10 Old 08-16-2017, 11:30 PM
azzkicker
2007 WK
I guess the A/C clutch could be slipping, but I usually see those fail to lock up, not slip. Yours is not failing to lock up.
post #6 of 10 Old 08-17-2017, 05:47 AM
jeepWK2007
2007 WK
i just had mine recharged- first time in 190k, made a world of difference
jeepWK2007 is offline
post #7 of 10 Old 08-17-2017, 05:59 PM
JackB1
2008 WK
A question about recharging. I have always over the years used the high pressure line kit with gauge and fed in freon bought at store. Recently I have been hearing that the system must be evacuated first by a Dealer. Has something changed over the years?
JackB1 is offline
post #8 of 10 Old 08-21-2017, 06:22 AM
keggles
keggles's Avatar
2008 WK
The can systems you get at the store work just fine, but if you were to truly vacate the HVAC system, pressure test, and refill; it can have better results. Moisture will wreak havoc on HVAC. The dealer while bend you over for these kinds of jobs. I went to HF and bought a $100 vacuum and its been used on 4 different vehicles, was a great investment. Just need to get some good gauges.
I'm a nut, but not just a nut.
08 WK 5.7 Hemi 4x4
06 WK 4.7 - RIP
Silver WK Club #63
keggles is offline
post #9 of 10 Old 08-22-2017, 08:41 AM Thread Starter
xjshellback
thanks for the help, everyone.
I have noticed the temp reading in the dash is way off when its blowing hot air and seems to improve as the temp gets to the actual outside temp.
the other day it was in the 90s but my dash was saying 79 for 5 miles or so and it blew hot air until it got to 93. the temp sensor is about 9 bucks so I am going to replace it and hope it helps.
post #10 of 10 Old 09-03-2017, 08:30 AM Thread Starter
xjshellback
i replaced the ambient air temp sensor but i don't think it made a difference as far as AC efficiency goes.
i did play with the Freon/pressures and seem to have got it right and have AC again. it hasn't been in the 90s since i got cold air back so i haven't been able to test it at its limits but i am good to go again.
thanks for the help.
