ac not blowing cold on passenger side - JeepForum.com
post #1 of 11 Old 08-19-2014, 06:03 PM Thread Starter
booked101
My ac will blow ice cold on the driver aide and warm on the passenger side. I can hear the actuator open the blend door on the passenger side when changing from hot to cold. Any other ideas?
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
post #2 of 11 Old 08-21-2014, 08:33 AM
amcfanatic
2009 WK
The actuator may be operating but the probable cause is the blend door is broken inside. The dashboard needs to come out to get to this door to fix it. This is not cheap to easy repair. This also appears to be a fairly common problem. Same thing happened to my 98 ZJ.
09 Overland 5.7 Hemi
98 5.9 Limited
80 CJ7
amcfanatic is offline
post #3 of 11 Old 08-21-2014, 11:38 AM
bobbylx
2008 WK
http://www.jeepforum.com/forum/f67/p...-door-2558154/
Read through the above thread. Try charging with refrigerant, worked for myself and quite a few others.
2008 Overland 5.7 Hemi
Modified Rusty's lift
JK Moabs/Nittos
Black WK Club #136
bobbylx is offline
post #4 of 11 Old 08-21-2014, 06:15 PM Thread Starter
booked101
That's what I was going to try first. Going to have my mechanic empty and refill the ac refrigerant.
post #5 of 11 Old 08-21-2014, 07:55 PM
amcfanatic
2009 WK
If refrigerant level was low then it would be blowing warm from both sides, not warm on one side and cold on the other.
98 5.9 Limited
80 CJ7
post #6 of 11 Old 08-21-2014, 08:27 PM
Crankshaft
2007 WK
If he has the dual climate zone AC, then it will blow cold on the driver side and warm on the passenger side when the refrigerant charge is low.
07' Jeep Grand Cherokee CRD
Crankshaft is offline
post #7 of 11 Old 08-21-2014, 08:49 PM
imthehink
imthehink's Avatar
Nope, I had the exact thing happen a couple years back. Checked refrigerant which was low, filled and no problems since. When low, the ac will default cold air to driver side. I do not have dual climate control btw. Also, if any of the actuators are bad, there will be an annoying click/tapping noise which are easily tracked down.
imthehink is online now
post #8 of 11 Old 08-22-2014, 07:25 AM
amcfanatic
2009 WK
This is a new one on me. Thanks for correcting me on this.
I apologize if I confused anyone.
98 5.9 Limited
80 CJ7
post #9 of 11 Old 08-22-2014, 01:52 PM
rutro
2006 WK
Hey my '05 WK with regular old A/C not dual did this very same thing. I chased around trying to make it be a blend door or an actuator until it started blowing warm on both sides. Then the compressor went out. Lack of refrigerant ..... Big repair instead of a can of refrigerant.
rutro is offline
post #10 of 11 Old 08-22-2014, 02:23 PM
Forcus
2005 WK
Ditto, had warm air on the passenger side, was low refrigerant. Added some but of course means an overhaul is in order..
2005 Grand Cherokee 4x4
1974 International 100 4x4
Forcus is offline
post #11 of 11 Old 09-06-2014, 11:27 AM
DCFD522
Having the same problem, dont hear a clicking from the actuator... and I had the refrigerant vacced and recharged. No change. Not dual zone either. Anyone know the location of the actuator if it's bad and if the entire dash needs to come out or not?
DCFD522 is offline
