AC fan strange noise and vibration. - JeepForum.com
post #1 of 8 Old 09-05-2013, 05:54 AM Thread Starter
filo8818
2007 XK Commander
Hello everyone,
Since a few days i realized a strange noise ( louder) form my jeep commanders 2007 ac fan.
The noise appear only if the fan is working fast ( from 3/4 to full), and the noise is like a stronger very hard to explain.
I try to switch the engine off and run just the fan to understand if it was linked with ac compressor or engine but is not.
What can be?
Where is located the fan?
Is hard, in case, to repalce it??
Thanks a lot
filo8818 is offline
post #2 of 8 Old 09-07-2013, 07:28 PM
trax95008
2006 XK Commander
Are you talking about the HVAC fan? The fan that makes air blow out of your vents? Or are you talking about the A/C compressor on the engine? Of its the HVAC fan, it sounds like you sucked in some debris. The fan is located under the dash o the passenger side. Very easy to remove and clean out
trax95008 is offline
post #3 of 8 Old 09-08-2013, 02:15 PM Thread Starter
filo8818
2007 XK Commander
Im quite sure is not the air compressor. I tried to run the fun without the engine running, so in this case cannot be the compressor.
The noise is like something touching the fan, but only when is going fast...
Sent from AutoGuide.com App
filo8818 is offline
post #4 of 8 Old 09-08-2013, 02:16 PM Thread Starter
filo8818
2007 XK Commander
Is there any tutorial about how to clean the fan? I mean just how to access it!
Thanks
filo8818 is offline
post #5 of 8 Old 09-08-2013, 02:59 PM
dgiessel
2006 WK
The blower motor for my A/C failed last month in the middle of a seven hour trip. Long story short: Hardly anybody, parts houses, dealerships, etc., has them in stock. I had to continue my trip an hour-and-a-half down the road to find someone that had a new motor in stock. Also, the new blower motor cost me just over $190.00. I learned a lot, though. I just wish I had been on top of things as you, because I might not have had to spend almost $200 on a new part, not to mention driving into the sun in triple digit temperatures with no A/C.
It still amazes me that such an expensive part for such an important function is so easy to access-- for which I am very glad.
Remove two black screws (Philips) from black piece of plastic under the glove box. The screws will be in the black plastic where the bottom of the glove box hinges outwards. Gently work the black piece of plastic out from underneath the dash.
To remove the blower motor, first disconnect the wires for the blower motor, as it will make things simpler. I had troubles doing this, but I'm probably the only person who does.
You will need a T20 Torx screwdriver to remove three, silver-colored screws that hold everything in. After that, it should just drop straight down and out.
The entire unit is one piece. It's just the squirrel cage fan (in case my terminology is wrong, it's basically just like a wheel that people's pet rodents typically run on) slipped over a shaft coming out of the motor itself.
Recap- two black screws (Philips) to remove a panel, and then three silver Torx screws (T20) to remove the fan/blower motor.
I took some pictures, but couldn't get them to upload. If you have any questions, feel free to send me a PM, I'd be more than happy to answer them.
dgiessel is offline
post #6 of 8 Old 09-08-2013, 03:43 PM Thread Starter
filo8818
2007 XK Commander
You are really more than nice.
Your tutorial is perfect. I ll try to do it asap especially cause im scared something little can became something serious and here in Italy were i live the jeep part cost 3 times more than usa!! So i really wanna avoid to change it!
Maybe just something is inside of it and when the fan is spinning fast is making noise.
If you have the picture and you email it to me i ll love it!!!
Thanks again for real!
filo8818 is offline
post #7 of 8 Old 09-08-2013, 03:49 PM Thread Starter
filo8818
2007 XK Commander
I also took a video that i ll upload to youtube but im really scared is impossible to identify the noise I'm talking about cause the air is blowing into the microphone.. But tomorrow i ll post the link so maybe it can help..
Here is the video..i hope someone with good hearing could understand what im talking about...
http://youtu.be/UvCvfivbR4s
filo8818 is offline
post #8 of 8 Old 09-19-2013, 02:53 PM Thread Starter
filo8818
2007 XK Commander
Ok today i finally did it...i removed the glove box and i face all the components...
actually the only think i removed was the one on the picture that i dont have any idea about it!! What is it? whats for??
i clean it up using air and now the strange noise seems gone....but how is possible???
filo8818 is offline
