AC Compressor chirping - JeepForum.com
post #1 of 6 Old 10-20-2013, 08:27 PM Thread Starter
05JGCWK
I have this very annoying chirp noise coming from the ac compressor pulley. I sprayed it with wd40 and it went away, but that only lasted for a bit and the sound came back. Does this mean that the compressor is going?
05JGCWK is offline
post #2 of 6 Old 11-03-2013, 11:40 AM Thread Starter
05JGCWK
05JGCWK is offline
post #3 of 6 Old 12-22-2013, 09:21 AM
Deanfly64
Bump for you.
I have the same thing in the wife's 08.
AW4 Swap-UCF Belly Up-Savvy GTS
-8.8 ChroMoly's Detriot Locker-
-D30 Elocker-Chromoly's-Trussed-
Deanfly64 is offline
post #4 of 6 Old 12-22-2013, 02:09 PM
hawgripper
2008 WK
Its usually the bearing in the clutch. U can have a shop replace the bearing for around $20 for the bearing. Most shops will try to replace the compressor but you can find the odd one that will do just the bearing. A lot cheaper than replacing the whole compressor.
hawgripper is offline
post #5 of 6 Old 12-22-2013, 02:20 PM
Deanfly64
Thanks!
Is that something I can do without breaking an AC line open.
post #6 of 6 Old 12-23-2013, 10:59 AM Thread Starter
05JGCWK
Crap...i forgot to post that i fixed it....turns out that it was a small crack in the belt. I replaced it and no more sound. For some reason i just thought of replacing that before the compressor...
05JGCWK is offline
