Abs light, traction control and no codes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Abs light, traction control and no codes
Gibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!
Unread 05-10-2015, 12:57 PM   #1
VT-05WK
2005 WK
Both lights are on but no codes show up when scanned with the key. Haven't done OBD 2 yet. What could be the issue?
'05 WK 4.7L V8, OME HD w/ Bilsteins, 1.5" Spidertraxx, Flowmaster 40 series
Cobra CB, Dipped Badges
VT-05WK is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 01:21 PM   #2
TurboDiesel
2008 WK
service electric brake system message too?
wheel speed sensors
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 01:32 PM   #3
VT-05WK
2005 WK
Yeah that's on too. Is that something I can do myself?
Unread 05-10-2015, 01:40 PM   #4
TurboDiesel
2008 WK
i tried to clean my WSS and it snapped off so i replaced the hubs..
i got my mechanic to do it but if u have the tools it didnt look too hard...
took him 45 minutes with an air hammer to get the old hub out tho lol
Unread 05-10-2015, 04:02 PM   #5
celica00gt
Mine did the same thing. Ended up being the wheel speed sensor. 16 dollar part and a half an hour to put on.
celica00gt is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 05:41 PM   #6
CavallinoRed
2006 WK
Stop by any of the big auto parts stores and they should be able to hook up to a reader to see if you have any active DTC's. Would let you know if a speed sensor is your problem and which corner if it is.
Seem to recall that on WKs R/L front are different part numbers but the one for the rears will work on either side.. but don't quote me on that.
CavallinoRed is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 09:11 AM   #7
VT-05WK
2005 WK
Did you have to remove anything like the calipers or rotors to access the wheel sensor? It appears that my backing plate is covering the bolt that holds the sensor in
Unread 05-12-2015, 11:43 AM   #8
VT-05WK
2005 WK
Nevermind I got it all changed
