9.5 MPG? How to improve? - Page 3 - JeepForum.com
post #31 of 42 Old 03-31-2013, 02:38 PM
jesse12801
If you never hit the highway the mpg's keep going down,down,down..hit the highway once in a while to raise it.Keep it around 65 when you do.07 GRAND CHEROKEE 3.7.
jesse12801 is offline
post #32 of 42 Old 03-31-2013, 08:50 PM
jaje
2007 WK
Originally Posted by trax95008 View Post
The risk of under inflating isn't tire wear, it's sidewall damage. The lower the pressure, the more the sidewall flexes and heats up and degrades resulting in a blowout.
This was the reason why the 90's and early 00's Ford Explorers were extremely dangerous on the highway. Ford had issued instructions to dealers to inflate tires to only 26 psi in order to make them more stable at highway speeds (they were very tippy from internal testing especially the 2 door sport version with very narrow length and width wheelbase). The owners almost never routinely checked their tire pressures leading to < 26 psi tires (and premature tire wear on the sidewalls) and when going 45+ mph they would blow out and flip over with amateur drivers killing most inside the vehicle. Often the only survivor in these single car rollovers was an infant in a childseat as they were short enough that the roof collapse did not endanger them as much. Sad stories about all this happening and reason why low pressure warnings or TPMS systems are standard on almost all SUVs sold today.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #33 of 42 Old 04-02-2013, 09:29 AM Thread Starter
ChanWK
2005 WK
Might give that shot. I got nothing to loose.
ChanWK is offline
post #34 of 42 Old 04-03-2013, 01:28 PM
grandcher0kee06
2006 WK
Reset the MPG's on the dash, if you havent done that since the previous owner had it that could help you get a more accurate calculation. It could say 9mpg but that might be with 50,000 miles worth of recorded driving that its getting 9mpg from. So when your just driving around town it wont change immediately or you wont see any differences. Hope this helped
2006 Grand Cherokee Limited, QDII, 4.7L V8, 245/65/17 Firestone Destination LE, smittybilt rear d ring shackle reciever,
Blue WK Club Member #9
grandcher0kee06 is offline
post #35 of 42 Old 04-03-2013, 01:37 PM
texan2
1978 CJ5
Originally Posted by BillyZim View Post
I could be wrong but I do remember reading that you should not use any spray throttle body cleaner on your wk. I do remember reading that it will cause damage.
My Hypertech programmer (part# 52501) gave me a gain of almost 2 mpg. It also improved acceleration. I readjusted my tire size with it too.
Is that programmer the type that you plug in, re-program and unplug? or do you leave it hooked up all the time?
texan2 is offline
post #36 of 42 Old 04-04-2013, 11:01 AM
Piepenbrok420
You unplug it
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #37 of 42 Old 04-04-2013, 04:37 PM Thread Starter
ChanWK
2005 WK
How would I reset it?
ChanWK is offline
post #38 of 42 Old 04-04-2013, 07:33 PM
Jeepforthewin
2010 JK Wrangler
Originally Posted by Atrain1066
I get 25mpg out of my 5.7L hemi - 12 around town, and 13 on the highway.
Hahaha well said! Same here for me glad I'm not the only one!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #39 of 42 Old 04-04-2013, 07:37 PM
Jeepforthewin
2010 JK Wrangler
When you have your MPG's showing in the evic screen just hit reset on the information center buttons.
post #40 of 42 Old 04-06-2013, 08:59 AM Thread Starter
ChanWK
2005 WK
Sounds good thanks
ChanWK is offline
post #41 of 42 Old 04-12-2013, 09:24 PM
dsjr2006
2006 WK
10 in town, 14-16 hwy seems to be about average. Also makes me wish I had the CRD!
'06 Limited Hemi QDII - Icon Coilovers - OME Lift w/Bilsteins - 32" 265/65R18 Goodyear Duratracs on JK Sahara 18s - Smittybilt XRC10 Comp X20 Winch
05-08 WK Service Manual PDF:
dsjr2006 is offline
post #42 of 42 Old 04-13-2013, 12:01 PM
leftoverture
2007 WK
I've been getting around 15-16mpg combined highway/city in my 4.7 Laredo. Only had it a week, though, so only about 770 miles to calculate it from. Temps have been in the 30's and low 40's during that time and I've used the cruise only sparingly on longer freeway runs. I did not buy this thing for the gas mileage though. I have my Corvette for that.
A well regulated militia being necessary to the security of a free state, the right of the people to keep and bear arms shall not be infringed.
leftoverture is offline
