9.5 MPG? How to improve? - Page 2 - JeepForum.com
post #16 of 42 Old 03-28-2013, 08:17 PM
Megs_Revenge
2005 WK
My hemi sucks gas as well. But, you don't really buy these Jeeps based on their excellent gas mileage.
2005 Silver WK 5.7L Hemi
Silver WK club #69
Oo|||||||oO
Megs_Revenge is offline
post #17 of 42 Old 03-28-2013, 08:26 PM
Atrain1066
2005 WK
I get 25mpg out of my 5.7L hemi - 12 around town, and 13 on the highway.
Atrain1066 is offline
post #18 of 42 Old 03-28-2013, 08:54 PM
trax95008
2006 XK Commander
Is that a joke?
trax95008 is offline
post #19 of 42 Old 03-28-2013, 11:21 PM
ahillstrom
2005 WK
I'd say so.
ahillstrom is offline
post #20 of 42 Old 03-29-2013, 06:30 AM
jaje
2007 WK
That is hilarious! Some of the Hemi Guys say they can get low 20's combined and high 20's highway. I think I now know their calculations.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #21 of 42 Old 03-29-2013, 08:29 AM
IndyBlueWK
2005 WK
i love to see 16 on the HWY.. hemi on 265's... I am thinking about throwing the stock intake back on to see if it gets better?
IndyBlueWK is offline
post #22 of 42 Old 03-29-2013, 08:50 AM
gtherman
Why are you telling people not to inflate over 32psi??? My door sticker says 35. Are you telling people to ignore their door sticker?
FWIW, ignore the door sticker if you have tires other than what came on the vehicle. The tires will have a range (25-40 PSI for example), and anything in that range is fine. Don't exceed that limit regardless of what the door sticker says. Usually the door sticker rating falls within the range of the tires, however sometimes this is not the case.
gtherman is offline
post #23 of 42 Old 03-29-2013, 09:04 AM
trax95008
2006 XK Commander
Yes I understand this and agree. I was just making a point at the fact that he specified a precise pressure, without any other explanation or advice. Lets say I still have my stock tires on, and he just told me to run them at a different pressure than what the manufacturer says. It's common to find bad advice on forums, and I was just speaking up to clarify what I considered to be bad advice
post #24 of 42 Old 03-29-2013, 07:32 PM
gtherman
Good. I just wanted to make it clear that the vehicle's specs were for a particular tire, not just any tire that Joe at the tire store sold you, and that you should always follow the tire specs. It seems as if we have an accord.
gtherman is offline
post #25 of 42 Old 03-30-2013, 10:28 PM
Walt
2008 WK
Originally Posted by ChanWK View Post
Hey,
So I recently just bought my first car and first jeep and for some reason my fuel economy has been awful. I checked my trip computer and I'm getting 9.5 MPG... I have about 83500 miles on it wondering what I could do to fix it. I've been looking around and people are saying things from new spark plugs, O2 sensors, throttle body cleaner, and new spark plug wires. Any help would be great.
Thanks.
Do you know any of the maintenance history? If not, I recommend picking a service interval from the owner's manual and doing everything to get it back to acceptable performance. For instance, use 60K miles to do the following:
- spark plugs
- PCV valve
- xmission fluid & filter(s)
- fluid change in xfer case & both axles
- new serpentine belt
- air intake filter
- EGR valve (optional)
- spark plug wires (optional)
Now you are starting from a position of knowledge.
Additional considerations:
- When performing normal tire rotations, inspect brake shoes and make sure that the brake pads are not dragging.
- Go to Advance Auto (or equiv) and borrow their code reader. See if there are any active or pending DTC's that you need to pay attention to. Hidden O2 sensor DTC's will adversely affect your mpg's.
Do these things after you check your tire pressures. BTW: I run mine at 34.5 psig cold. Door sticker says 33 psig and tire dealer puts them at 37 psig (I have no idea why) and the ride is uncomfortable at that level.
As a point of comparison, I get 14.5 mpg around town and 18.5 mpg in the 5.7L HEMI.
Hope this helps somewhat. CAUTION: This advice may be worth what you paid to get it!
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #26 of 42 Old 03-31-2013, 11:43 AM
hxdrummerxc
2008 WK
So far, the highest that I have seen was 20.2 mpg hwy.
Stock everything, stock tire size.
That is using cruise control for about 3 hours straight just to get it that high.
Right now, im only averaging 13.4 mpg
Maybe because its winter, but also because Its hard for me to stay light on the throttle. a part of me doesn't care about the bad gas mileage at all...... but the other part..... the money part, hates it.
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #27 of 42 Old 03-31-2013, 12:03 PM
suzieque
2008 WK
Originally Posted by trax95008 View Post
Why are you telling people not to inflate over 32psi??? My door sticker says 35. Are you telling people to ignore their door sticker? And what if I had a heavy load in the back and needed a few more pounds to compensate??? I don't understand why your giving this advice...
there are many threads on the net debating tire inflation.
the best info I read to date suggests the door sticker is guidance for ride comfort. The actual tire optimal inflation is 10% less than the number stamped on the sidewall of the tire itself, inflation is measured when the tire is cold (e.g. parked overnight in the garage out of the sun). In my case, this inflation amount (10% less than the number stamped on the sidewall of the tire itself) was higher than the door sticker.
I've read that inflation advice for about a year now, seems fine and no abnormal tread wear, just a firmer ride in the vehicle.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #28 of 42 Old 03-31-2013, 12:29 PM
trax95008
2006 XK Commander
The risk of under inflating isn't tire wear, it's sidewall damage. The lower the pressure, the more the sidewall flexes and heats up and degrades resulting in a blowout.
post #29 of 42 Old 03-31-2013, 01:51 PM
Piepenbrok420
You people are pretty funny, I work on cars for a living so it's pretty entertaining to see what people think is right for their vehicle. I run 40-50 psi in my Load Range E 33" (285/70r17) mud terrains.
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #30 of 42 Old 03-31-2013, 02:01 PM
suzieque
2008 WK
I do computer support for a living and I read lots of posts from experts arguing about the correct answer to a computer problem.
suzieque is offline
