5 to 8 second tranny lag? - Page 2 - JeepForum.com
post #16 of 19 Old 08-05-2007, 09:31 AM
T-Rated
T-Rated's Avatar
First glance on the P2181 is Cooling System; often the sensor.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #17 of 19 Old 08-05-2007, 01:26 PM
merlinTec
merlinTec's Avatar
P2181-COOLING SYSTEM PERFORMANCE
Set Condition:
PCM recognizes that the ECT Sensor has failed its self coherence test. The coolant temp should only change at a certain rate, if this rate is too slow or too fast this fault will set. Two trip fault. Three good trips to clear MIL. The MIL and ETC light will illuminate.
· Possible Causes
LOW COOLANT LEVEL
(K2) ECT SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K2) ECT SIGNAL CIRCUIT OPEN
(K900) SENSOR GROUND CIRCUIT OPEN
(K2) ECT SIGNAL CIRCUIT SHORTED TO GROUND
(K2) ECT SIGNAL CIRCUIT SHORTED TO THE (K900) SENSOR GROUND CIRCUIT
THERMOSTAT
ECT SENSOR
PCM
NOTE: If an Engine Coolant Temperature (ECT) DTC is set along with this code, diagnose the ECT DTC first.
NOTE: Inspect the ECT Sensor terminals and related PCM terminals. Ensure the terminals are free from corrosion and damage.
NOTE: The best way to diagnose this DTC is to allow the vehicle to sit overnight outside in order to have a totally cold soaked engine.
NOTE: Extremely cold outside ambient temperatures may have caused this DTC to set.
NOTE: Need to make sure that no Cooling System DTCs are set or changes that would make the warm up much slower or much faster: broken water pump can set this, addition of aftermarket auxiliary cooler can set this DTC.
Was that the only code? I see there is a software update for the PCM but not for your fault but always best to have the latest software level so I would ask them to check this and update if it has not already been done.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #18 of 19 Old 08-05-2007, 02:53 PM Thread Starter
heesman
Merlin,
Thanks for the reply!
The last time it was at the dealership they updated the PCM - they affixed a sticker under the hood stating that they did. So I know that part has been taken care of.
I will call the dealer first thing tomorrow morning.
Thanks again, I really do appreciate experts chiming in - very, very cool.
Eric
heesman is offline
post #19 of 19 Old 08-05-2007, 02:59 PM
merlinTec
merlinTec's Avatar
Hi Eric
they should have put the part number on that label if you want me to I can tell you if it's the latest update.
tranny go bye bye ccppcc90 ZJ Grand Cherokee Forum 12 07-29-2008 04:30 PM
95ZJ tranny mount with a 96ZJ tranny? Vanisle4x4 ZJ Grand Cherokee Forum 0 07-12-2008 03:46 PM
tranny not sure what to do? nashmd454 ZJ Grand Cherokee Forum 3 06-27-2008 03:01 AM
Tranny rossj711 ZJ Grand Cherokee Forum 6 08-28-2006 09:25 AM
242 Swap Done, Bad Tranny, Please read!!! a few Tranny ?'s TGMInd ZJ Grand Cherokee Forum 2 04-29-2004 08:33 PM
