5.7L QDII Differential Lube Change - JeepForum.com
post #1 of 4 Old 05-29-2012, 08:35 PM Thread Starter
DRCracker
2006 WK
Today I changed the gear lube on my '06 WK 5.7L Hemi with QDII.
This WK is not lifted, stock suspension, but easy to reach everything.
I used Amsoil Severe Gear 75W-140 lube and their Slip Lock additive for the limited slip diff's.
Also used a fluid pump from Lowe's. Not endorsing any products here, but thought you'de like to know.
The photo's are pretty much self explanatory;
Removed the rubber plug from the rear diff.
Used the drill/pump to remove the old gear lube, it was black.
Bought the WK with over 60K miles and it doesn't look like this has ever been changed before?
The pump made this painless and quick!
Added the "Slip Lock" first.
Pumped in the "Severe Gear" Lube, big difference in color from the old lube.
Took 2 whole quarts, so I think I got most of the old stuff.
Replaced the rubber plug, took about 10 min. tops.
Front diff was more challenging;
Removed the skid plate with 13mm socket, removed rear bolts, and loosened front bolts. The front slid out of the way easily.
Removed top fill plug, but a socket wrench wouldn't fit with the 14mm hex socket I had. So I used a 15mm craftsman wratcheting wrench on the 14mm hex to get it loose, necessity is the mother of invention.
Removed the lower drain plug with a socket and 14mm hex socket.
Diff drained easily into oil bucket.
Replaced drain plug using teflon tape, FSM says torque to 15-25 ft./lbs.
I used a torque wrench at 20 ft./lbs. here.
Added "Slip Lock" here too.
Used pump to fill the upper hole, routed hose over crossmember.
Once it was full, took less than 2 quarts, I replaced the plug.
Just used the wrench trick again, but couldn't measure torque,
good and tight.
Everything was easy to reach from my back on the driveway.
Took about an hour.
We'll see how the Amsoil performs, but I expect no problems.
Maybe even get more mpg's too!
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #2 of 4 Old 05-29-2012, 09:06 PM
rraiderr
2010 WK
Nice post, thanks.
rraiderr is offline
post #3 of 4 Old 06-03-2012, 05:10 PM
longboy
2006 WK
Nice post...I'll get to mine one of these weekends once I get the friction modifier.
2006 5.7l WK
longboy is offline
post #4 of 4 Old 06-03-2012, 06:33 PM
modernblueWK
I hope their ls additive works for you. I would get the jeep stuff to be 100% sure.
The auburn gear limited slip i have in my hotrod rearaxle only likes ford additive.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
Rear differential protection for QDII? blizzboy283 WK Grand Cherokee & XK Commander Forum 13 04-30-2014 12:37 AM
QDII Diff and T-case fluid change LordEnki WK Grand Cherokee & XK Commander Forum 13 12-17-2011 02:32 PM
'08 WK QDII Fluid Change Help Please jeffjs WK Grand Cherokee & XK Commander Forum 17 07-27-2011 09:28 AM
WJ QDII Differential/T-Case Life & Maintenance DJGWJ ZJ Grand Cherokee Forum 6 04-11-2009 12:41 PM
07 QDII Diff Fluid Change phillyeaglekgd WK Grand Cherokee & XK Commander Forum 3 11-10-2008 05:21 PM
