5.7L Hemi - Coolant Leak - JeepForum.com
post #1 of 16 Old 09-26-2013, 11:57 PM Thread Starter
twingler
2005 WK
My 2005 Limited WK started leaking coolant in the past few days. Started as a small puddle under front bumper, driver side. I noticed it after parked for about 15min. Puddle about 4-6" round. But getting worse, today I parked, got out and see coolant steady dripping in the same area. I don't see any sign of coolant leaking from under the hood. nor do I see it leaking underneath around the water pump/engine. I'm thinking its the radiator leaking. No overheating.... oh and I live in Phoenix. So it's always hot. Can anyone else confirm my suspision of a radiator leak or should I check something else first - cap, overflow tank, etc ???
twingler is offline
post #2 of 16 Old 09-27-2013, 06:59 AM
Jeepforthewin
2010 JK Wrangler
Get a pressure test done. Should be able to pinpoint where it is leaking from.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 16 Old 09-28-2013, 10:44 AM Thread Starter
twingler
2005 WK
pressure testing to 15psi revealed a leak at the thermostat housing gasket. Thinking I'lll go ahead and replace all coolant system parts, radiator, water pump, thermostat, hoses and drive belt. I bought this Jeep used with 105k miles.... now has 130k and I want to keep her in top shape.
twingler is offline
post #4 of 16 Old 09-29-2013, 02:31 PM
Burnerman
Burnerman's Avatar
I just replaced the thermostat today, same small leak. The thermostat I took out was wasted! It has a permanent rubber gasket around the perimeter that was torn and the guts of the thermostat were missing pieces of rubber.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 16 Old 09-30-2013, 10:07 AM
Shafer57
2006 WK
If it aint broke, don't fix it
Living in Phoenix though I understand your reasoning. But i'd simply swap out the stat, and maybe have the coolant system serviced. I personally wouldn't go replacing all of that if the fix might be as minor as a $6 thermostat
Just my .02
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #6 of 16 Old 10-01-2013, 11:22 AM
XK1982
2006 XK Commander
Just my .02
Agreed! Just get the thermostat and in the process you'll have to replace all the coolant anyway. I definitely wouldn't replace the radiator unless you just have $$ to burn! Good luck!
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #7 of 16 Old 10-02-2013, 01:03 PM Thread Starter
twingler
2005 WK
Thanks for the feedback and opinions guys. I'll go with the Tstat / gasket first and new coolant.
twingler is offline
post #8 of 16 Old 10-02-2013, 01:53 PM
yzjwk
2005 WK
Make sure they use HOAT coolant . As far as i know MOPAR or Zerex G-05 are your only options .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #9 of 16 Old 10-02-2013, 04:11 PM
Walt
2008 WK
... I'll go with ...new coolant.
The MOPAR HOAT is not diluted, so prepare a 50/50 mix when replacing it. FWIW, mine was on sale at $18/gallon at the Jeep dealer. Regular price was $25/gallon.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #10 of 16 Old 10-03-2013, 07:20 AM
Burnerman
Burnerman's Avatar
I purchased MOPAR 50/50 hoat coolant at the dealer for less then $12 a gallon. It was cheaper then the Zerex at the parts store.
96 ZJ.
post #11 of 16 Old 10-04-2013, 11:35 AM Thread Starter
twingler
2005 WK
Burnerman - Thanks for the dealer tip....however My local dealer was $47/gallon for pre-mix. Parts store is $18/gallon pure for G-O5.
Another general question - Anyone used a Pre-flush cleaner product? Suggestions / comments??
twingler is offline
post #12 of 16 Old 10-04-2013, 12:11 PM
Burnerman
Burnerman's Avatar
$27!!!!! Holy spit!!!!
96 ZJ.
post #13 of 16 Old 11-17-2014, 01:14 PM
unobtanium
Well, my jeep just puked up all its coolant. I am unsure where it's coming from. The entire front of the engine and fan-shroud of the radiator is covered. It looks like a pressure test is in order. This is gonna cost
Water pump was just done 20K miles ago at 62K miles. *sigh* Chrysler...oh, Chrysler...never again.
ETA: To get across town to the dealer, I am planning on filling it with distilled water. I know this is not a long-term solution, as it needs fixing or it will all just leak out again, but I am correct in presuming this is better than tap water with all the chlorine and fluoride and other crap in it?
Traded the '10 WK w/Hemi and QD2 in on 5/15/15 for a '15 mazda CX-5 2.5L AWD Touring. Happier!
unobtanium is offline
post #14 of 16 Old 11-18-2014, 08:26 AM
Quinny
2006 WK
I'd just stick tap water in..... It'll chuck a load out on the trip to the dealer, and he'll have to replace the coolant anyway when he finds the problem..
Quinny is offline
post #15 of 16 Old 11-18-2014, 09:05 AM
ravenworks
I'd tow it
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
Coolant leak , hemi , radiator
