-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   5.7L Hemi - Coolant Leak (http://www.jeepforum.com/forum/f67/5-7l-hemi-coolant-leak-1627473/)
twingler 09-26-2013 11:57 PM
My 2005 Limited WK started leaking coolant in the past few days. Started as a small puddle under front bumper, driver side. I noticed it after parked for about 15min. Puddle about 4-6" round. But getting worse, today I parked, got out and see coolant steady dripping in the same area. I don't see any sign of coolant leaking from under the hood. nor do I see it leaking underneath around the water pump/engine. I'm thinking its the radiator leaking. No overheating.... oh and I live in Phoenix. So it's always hot. Can anyone else confirm my suspision of a radiator leak or should I check something else first - cap, overflow tank, etc ???
Jeepforthewin 09-27-2013 06:59 AM
Get a pressure test done. Should be able to pinpoint where it is leaking from.
twingler 09-28-2013 10:44 AM
pressure testing to 15psi revealed a leak at the thermostat housing gasket. Thinking I'lll go ahead and replace all coolant system parts, radiator, water pump, thermostat, hoses and drive belt. I bought this Jeep used with 105k miles.... now has 130k and I want to keep her in top shape.
Burnerman 09-29-2013 02:31 PM
I just replaced the thermostat today, same small leak. The thermostat I took out was wasted! It has a permanent rubber gasket around the perimeter that was torn and the guts of the thermostat were missing pieces of rubber.
Shafer57 09-30-2013 10:07 AM
If it aint broke, don't fix it
Living in Phoenix though I understand your reasoning. But i'd simply swap out the stat, and maybe have the coolant system serviced. I personally wouldn't go replacing all of that if the fix might be as minor as a $6 thermostat:thumbsup:
Just my .02
XK1982 10-01-2013 11:22 AM
Just my .02
Agreed! Just get the thermostat and in the process you'll have to replace all the coolant anyway. I definitely wouldn't replace the radiator unless you just have $$ to burn! Good luck!
twingler 10-02-2013 01:03 PM
Thanks for the feedback and opinions guys. I'll go with the Tstat / gasket first and new coolant.
yzjwk 10-02-2013 01:53 PM
Make sure they use HOAT coolant . As far as i know MOPAR or Zerex G-05 are your only options .
Walt 10-02-2013 04:11 PM
Originally Posted by twingler (Post 16498841)
... I'll go with ...new coolant.
The MOPAR HOAT is not diluted, so prepare a 50/50 mix when replacing it. FWIW, mine was on sale at $18/gallon at the Jeep dealer. Regular price was $25/gallon. :thumbsup:
Burnerman 10-03-2013 07:20 AM
I purchased MOPAR 50/50 hoat coolant at the dealer for less then $12 a gallon. It was cheaper then the Zerex at the parts store.
twingler 10-04-2013 11:35 AM
Burnerman - Thanks for the dealer tip....however My local dealer was $47/gallon for pre-mix. Parts store is $18/gallon pure for G-O5.
Another general question - Anyone used a Pre-flush cleaner product? Suggestions / comments??
Burnerman 10-04-2013 12:11 PM
$27!!!!! Holy spit!!!!
unobtanium 11-17-2014 01:14 PM
Well, my jeep just puked up all its coolant. I am unsure where it's coming from. The entire front of the engine and fan-shroud of the radiator is covered. It looks like a pressure test is in order. This is gonna cost :(
Water pump was just done 20K miles ago at 62K miles. *sigh* Chrysler...oh, Chrysler...never again.
ETA: To get across town to the dealer, I am planning on filling it with distilled water. I know this is not a long-term solution, as it needs fixing or it will all just leak out again, but I am correct in presuming this is better than tap water with all the chlorine and fluoride and other crap in it?
Quinny 11-18-2014 08:26 AM
I'd just stick tap water in..... It'll chuck a load out on the trip to the dealer, and he'll have to replace the coolant anyway when he finds the problem..
ravenworks 11-18-2014 09:05 AM
I'd tow it
The time now is 02:01 PM.
