5.7 vs 6.1 coils - JeepForum.com
post #1 of 6 Old 12-20-2015, 02:28 PM Thread Starter
JakeWK
2005 WK
5.7 vs 6.1 coils
I am looking at some coil pack covers, such as the link attached, for my 5.7L. I can only find 6.1 covers, but the coil pack setup looks identical.. Does anyone know if the coil pack setup for the 6.1 is the same as the 5.7? This particular manufacturer states compatibility with 5.7, 6.1, 6.4L engines. Despite the difference in displacement, am i correct in assuming that the coil packs are the same and so the cover will be compatible? Did the coil pack setup change any between 2005-2010? Thanks!
http://3rdstrikeperformance.com/inde...ducts_id=10766
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #2 of 6 Old 12-20-2015, 02:56 PM
JRLT
2010 WK
The 5.7L and 6.1L have the same part numbers for ignition coils.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 6 Old 12-20-2015, 02:58 PM
90grandoneer
90grandoneer's Avatar
2006 WK
The 05 coil packs are different from the 06 and up coil packs. Yours has the coil over one plug, with a wire crossing over to a cylinder on the other side (Wasted Spark System), and the 06's and up have the coil over both plugs with no spark plug wires. The valve covers are different and the electrical plugs and pinouts are also different between the 05's and the 06's>. The bolt patterns of the actual valve covers of all the Hemi's is the same though, so the coil pack covers may work, especially if you use Taylor Shorty wires, and the coil covers bolt to the valve cover bolts. They probably won't work if they bolt to the coil mount bolts though since those bolt patterns between the two are different.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #4 of 6 Old 12-20-2015, 06:07 PM Thread Starter
JakeWK
2005 WK
Thanks 90! i knew you'd respond to this, since you did the coil swap. Yeah i have the Shorty wire install, to get rid of the Wasted Spark. The fact that the manifold covers are the same is very helpful, as i imagine that's what the coil covers would mount on to. Thank you for your help! Now to just find a good cover set that isn't the $300 BT set. Haha
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #5 of 6 Old 12-20-2015, 06:08 PM Thread Starter
JakeWK
2005 WK
Thanks for the help man. I am looking into doing the 6.1 coil swap very soon anyway, and figured a pretty cover would really help the aesthetics. Also, when i was cleaning the dust off the valve cover and coil packs today, i thought a cover might help avoid that. Thanks!
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #6 of 6 Old 12-20-2015, 06:25 PM
90grandoneer
2006 WK
My Post No. 9 of the attached thread shows my 05 Hemi LX with the Taylor Shorty's on it and then the late model setup. The complete changeover (valve covers, new late model electrical plugs and coils) will cost you around $500-600, depending on what kind of deal you can get. I bought the SOS high output coils and have them on my WK also. I used the 06 5.7 Hemi WK composite valve covers too.
http://www.jeepforum.com/forum/f67/f...wires-3531634/
