5.7 hemi stalling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 5.7 hemi stalling
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 11-30-2014, 09:24 AM   #1
kris06
2006 WK
5.7 hemi stalling
Hello i need help with my jeep its 06 gc and its stalling at stops changed egr plugs from dealer o2 sensors changed throttle body and also torqe coverter camshaft sensor and crankshaft sensor and still stalling when shifting to drive from park when cold , when warmed up its just jerking with rpms 84k miles on the clock any ideas?
kris06 is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 10:51 AM   #2
rsurran
Codes?
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 11:01 AM   #3
kris06
2006 WK
No codes
Unread 11-30-2014, 12:55 PM   #4
CavallinoRed
2006 WK
Have you replaced the spark plugs recently?
CavallinoRed is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 02:31 PM   #5
Walt
2008 WK
Originally Posted by kris06 View Post
Hello i need help with my jeep its 06 gc and its stalling at stops. changed egr, plugs from dealer, o2 sensors, changed throttle body, and also torque converter, camshaft sensor, and crankshaft sensor... and still stalling when shifting to drive from park when cold , when warmed up its just jerking with rpms. 84k miles on the clock any ideas?
1. Check that the spark plugs have the dark center upper electrodes (where the coil connects). They should be MOPAR OEM or Champion 570, but definitely with the dark top. There is a STAR Case on this. Change them every 30K miles. Gap is 0.043" and torque at 12-15 lb-ft. 90grandoneer uses NGK's and they seem to work for him. I've used only Champion or MOPAR on my 5.7L HEMI.
2. Verify that xmission fluid is full when hot. ATF+4. Some members have reported that low fluid level has caused stalling problems.
3. PCV valve was due at 60K miles. Do you know if it was done?
You said there were no codes set (DTC). Were there any DTC's pending? A small exhaust leak at the Y-pipe connection to the manifolds will give you performance fits if not corrected. Mine need to be done annually or it sets a pending DTC and MDS does not function. Try torqueing yours also.
CAUTION: This advice may be worth what you paid to get it.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 04:40 PM   #6
kris06
2006 WK
No pending codes but i will check y pipe and spark plugs
Unread 11-30-2014, 06:53 PM   #7
alberto68888
2008 WK
Same problem with my 2008 GC 4.7 changed crankshaft, sparkplugs, cats, pcv, cleaned TB and fuel injectors. It's stall even while driving but all started when i cleaned the injectors and no DTC. Fuel pump pressure checked and was fine.
alberto68888 is offline   Reply With Quote Quick reply to this message
