4x4 or not? - JeepForum.com
post #1 of 9 Old 08-03-2007, 10:44 PM Thread Starter
lookn4aJP
4x4 or not?
as the proud owner of an 06 commander, where is the 4x4 switch on this thing? it says 4x4 on the liftgate,but i cant see any switch other than the little button under the radio that is the ESP button! is this what controls the 4x4?....thanks
lookn4aJP is offline
post #2 of 9 Old 08-03-2007, 10:59 PM
T-Rated
T-Rated's Avatar
If it's 4x4, then it's full time and can't be switched off. Check out this site for loads of great info:
http://www.xkjeeps.com
p.s. ESP is part of the traction control system. Hitting this button (or holding it for more than 5 seconds) disables various aspects of the system.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #3 of 9 Old 08-03-2007, 11:16 PM
gornoman
2006 WK
Sounds like your Commander is a 3.7 with Quadra Trac I, no transfer case for Low range. Fair enough trail runner, but not a "wheeler".
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
post #4 of 9 Old 08-04-2007, 09:04 AM
T-Rated
T-Rated's Avatar
I wouldn't say it's not a "wheeler." I take my WK out a bunch and the only time I use Low is for rock crawling. Well, I do have QuadraDrive II, which helps a lot, but a decent 4x system such as QuadraTrac I can still get you around pretty well.
T-Rated is offline
post #5 of 9 Old 08-04-2007, 09:59 AM Thread Starter
lookn4aJP
thanks all for info!!
so my 4x4 system just activates by itself when it senses wheel slippage or something?
post #6 of 9 Old 08-04-2007, 10:34 AM
goose1
Not really. Your 4x4 system is a constant 48/52 front/rear split. If slippage is detected the center diff (and computer) can divert up to 100% of the total power to either the front or rear axle. In conjunction with this is the Brake Traction Control System (BTCS) that is working in tandem with your ABS to brake a wheel that looses traction and divert power across the front or rear axle differential to the wheel with "more" traction.
2006 Jeep Grand Cherokee Laredo (WK) 28E
4.7 V8, Quadra-Trac II, Black Exterior, Light Khaki Interior
Upgraded: Mopar Sport Utility Crossbars
2008 Jeep Patriot Sporkt (MK) 26E
2.4L, CVVTII, 2WD, Black Exterior, Dark Gray Interior
goose1 is offline
post #7 of 9 Old 08-04-2007, 10:39 AM
merlinTec
merlinTec's Avatar
No yours is constant 4v4 same as all of them
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #8 of 9 Old 08-04-2007, 02:05 PM Thread Starter
lookn4aJP
great info!
not many of these around here,so i get lots of looks.anyways thanks much
post #9 of 9 Old 08-04-2007, 03:01 PM
gornoman
2006 WK
I always thought that rock crawling (using Low Range Gearing) is where "trail-riding" stopped and "wheeling" began. But then again, I'm just an old flatlander. LOL!!!
lookn4aJP, that Commander will surprise you with it's capabilities. Have fun!
My other passion -
gornoman is offline
