4x4 and 22in wheels? - Page 2 - JeepForum.com
post #16 of 27 Old 02-28-2013, 12:35 PM
jjt250
2007 WK
Originally Posted by LJS8510 View Post
Thanks I fixed the numbers
255/55/17 will not fit in stock spare location,
that would suck to have to keep it in the rear....
You might need a worn one and air it down...I think Omelet did it, maybe ask him.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #17 of 27 Old 02-28-2013, 12:44 PM
LJS8510
LJS8510's Avatar
2015 WK
Actually I think I would need to wear down the four on the jeep & keep the spare new!
I wonder if there are any warnings to not air down only the rear tires or only the front tires? the diameter of the air down tires is different?
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #18 of 27 Old 02-28-2013, 01:07 PM
jjt250
2007 WK
I don't think it's as big of a deal off road with airing down because you're generally on looser terrain. I was referring to airing down the spare tire to make it fit, however.
jjt250 is offline
post #19 of 27 Old 02-28-2013, 01:33 PM
LordEnki
2006 WK
Thats a half inch... I wouldn't put it on as spare.
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #20 of 27 Old 02-28-2013, 01:35 PM
rollindom
rollindom's Avatar
2005 WK
I had a tire go bad on my old ride, a 2005 Escalade. It like our WK was full time 4 wheel drive. The tire place I bought my tires from told me I had to replace all 4 tires or sign a waiver not holding them responsible for damage to the drivetrain if I only replaced 1 tire (I took a nail to the sidewall). This was even though all tires were the exact same size but the existing tires were down to like 50-60 percent tread. They told me overall diameter must be exact of damage can and will occur.
rollindom is offline
post #21 of 27 Old 03-01-2013, 04:55 AM
blizzboy283
2005 WK
It fits after doing the rear hitch mod and it being aired down.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #22 of 27 Old 03-02-2013, 09:33 AM Thread Starter
DetroitMuscle
2008 WK
Well here they are on the WK. Ride is notably improved. Handling is great... man do they grip.
I had originally thought about going Nitto Grapplers on some 17s but when I came across this deal($1000) with BRAND NEW nittos and the wheels (brand new) I had to jump on it.
I love it. I think only other things I will do is a CAI and eventually an exhaust.
A buddy suggested a bolt-on turbo... ?
Joe
Semper Fi
-Jeep n00b.
New owner of (used) 2008 Grand Cherokee Laredo WK.
DetroitMuscle is offline
post #23 of 27 Old 03-02-2013, 11:09 AM
JRLT
2010 WK
I'd get a Hypertech tuner before the CAI. Didn't know about an available turbo.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #24 of 27 Old 03-02-2013, 12:10 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
To the OP, the SRT tires are the same diameter, the difference is that the rear tires are wider than the front. But the diameter is the same.
I have a 255/75R17 in the stock location, so it will fit. Also from what I have come to understand from the Jeep engineers, the QD2 system is able to compensate for a tire size difference at low speeds. That is why I have been able to get away with using a 32" tire for a spare while running 33" tires. Russ does the same thing. He is the one who I got my info from. He had a 265/70R17 spare while running 295/70R17 tires. Basically what I was told is that if need be you can swap the spare on and limp to the nearest service station and the QD2 system will compensate, just don't try to fly around doing freeway speeds. I have never tested this though. I do carry a quality tire repair kit with me so I have it before I have to swap the spare in.
Omelet is offline
post #25 of 27 Old 03-02-2013, 12:17 PM
LJS8510
LJS8510's Avatar
2015 WK
DetroitMuscle
That looks great!
but probably wouldn't take it off road
I thought I remembered reading that somewhere just could not find it.
Thanks
LJS8510 is offline
post #26 of 27 Old 03-02-2013, 02:30 PM Thread Starter
DetroitMuscle
2008 WK
Thanks for the tip. DEF going to look into it.
Changed out the antenna for a black/nubby rubber thing. Will post new pics.
Joe
Semper Fi
-Jeep n00b.
post #27 of 27 Old 03-02-2013, 02:34 PM
JRLT
2010 WK
Look into a modified throttle body too. http://www.thefastman.com/
JRLT is offline
