40mph feels like I'm going over small bumps.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 40mph feels like I'm going over small bumps..
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 01-13-2009, 12:14 PM   #1
BlueTJMCRT
2005 WK
2005 Laredo 4.7
Crusing around 35-40 mph I have some weird "shutter" feeling in the jeep. Almost like I'm going over very small speed bumps until I give it some gas. Under acceleration it seems to go away.
My wife has asked me a couple times (is that the road or your jeep)....
Thanks for any info fella's!
97 TJ, Doo_Dads all over it, Somewhere in Colorado Wheeling.....
BlueTJMCRT is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 01:25 PM   #2
CRDTONKA
Sounds like a bad drive shaft u-joint to me. I would have it checked out.
CRDTONKA is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 03:06 PM   #3
DanF
2005 WK
I had a problem with my 2005 hemi where it felt like I was going over little expansion strips. It was most noticable around 35-40 mph. It took the dealer a few days to figure out it was a bad left front wheel bearing.
DanF is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 04:27 PM   #4
JMorash
2005 WK
That shutter feeling. could be the same problem alot of people have been expierencing with the 05 Grand Cherokees, where the lock up converter is engaging and disengaging improperly, as well as the Transmission computer is having issues.
My 05 WK does the same thing at that speed. Taking it to the dealer soon, but have found many threads and posts on this issue. So far no fix.
JMorash is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 10:25 PM   #5
ItalianJeeper77
2015 KL Cherokee
or it could be snow or mud in your rims that is throwing off your alignment..... that happens to me all the time, i pull over, kick the snow out and the shutter goes away.
1996 ZJ *Sold | 2000 WJ *Sold | 2005 WK *Sold | 2008 WK *Sold
2015 KL
ItalianJeeper77 is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 10:09 AM   #6
BlueTJMCRT
2005 WK
It's not snow or mud in the wheels. I'm very good at keeping the tires rotated and balanced also. Does anyone have a link to the lock up converter thread that might be of importance to me before I take it in the stealership?
Thanks!
Unread 01-14-2009, 12:16 PM   #7
JMorash
2005 WK
Its time for a new torque converter.
APS precision mfg makes really good ones. Makes your car faster!!!
Here are some links another member sent to me. Very useful
Do Not Edit! -->
<TITLE>Bookmarks</TITLE>
<H1>Bookmarks</H1>
<DL><p>
<DT><A HREF="http://www.dodge-nitro.com/dodge-nitro/f11/25-30mph-shuddering-272/" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402200">25-30mph shuddering - Dodge Nitro Forum</A>
<DT><A HREF="http://www.jeepforum.com/forum/showthread.php?t=541111" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229411334">50MPH problem might be torque converter - JeepForum.com</A>
<DT><A HREF="http://www.aa1car.com/library/2003/ic60340.htm" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229403066">Automatic Transmission Repair & Replace</A>
<DT><A HREF="http://www.allpar.com/fix/torque-converter.html" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402710">Chrysler, Plymouth, and Dodge Four-Speed Automatic Transmission Torque Converter Disabling</A>
<DT><A HREF="http://modsfaceoff.com/2005_chrylser_300_TSB/21-011-05.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229408845">http--modsfaceoff.com-2005_chrylser_300_TSB-21-011-05.pdf</A>
<DT><A HREF="http://project-jk.com/images/tsb/TSB_21-002-07-REVB.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229412323">http--project-jk.com-images-tsb-TSB_21-002-07-REVB.pdf</A>
<DT><A HREF="http://project-jk.com/index.php/?p=114" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229412572">http--project-jk.com-index.php-p=114</A>
<DT><A HREF="http://www.alldata.com/techcorner/tech2/tech%20tips/sept/mitsubishi_torque_converter_shudder.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229408201">http--www.alldata.com-techcorner-tech2-tech%20tips-sept-mitsubishi_torque_converter_shudder.pdf</A>
<DT><A HREF="http://www.sonnax.com/tech-articles/TB-VOL1-NO2.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229411796">http--www.sonnax.com-tech-articles-TB-VOL1-NO2.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/misc/LX/TSB/Rapid_Response_07001.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229407745">http--www.wkjeeps.com-misc-LX-TSB-Rapid_Response_07001.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/misc/LX/TSB/TSB_2100207e.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229410149">http--www.wkjeeps.com-misc-LX-TSB-TSB_2100207e.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/misc/LX/TSB/TSB_2100306.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229401989">http--www.wkjeeps.com-misc-LX-TSB-TSB_2100306.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/misc/LX/TSB/TSB_2101207.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402055">http--www.wkjeeps.com-misc-LX-TSB-TSB_2101207.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/tsb/tsb_wk_1801205.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229476229">http--www.wkjeeps.com-tsb-tsb_wk_1801205.pdf</A>
<DT><A HREF="http://www.wkjeeps.com/tsb/tsb_wk_2100205.pdf" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229401995">http--www.wkjeeps.com-tsb-tsb_wk_2100205.pdf</A>
<DT><A HREF="http://www.automotivehelper.com/topic303637.htm" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402878">Line pressure & torque converter shudder - Automotive Message Forums</A>
<DT><A HREF="http://www.intl-tbirdclub.com/Articles/2005May-Jun_94-97Trans-Torque.html" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229408581">The ITC Wants You!</A>
<DT><A HREF="http://www.shoupsauto.com/Tips.htm" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402700">Torque Converter Shudder</A>
<DT><A HREF="http://www.300cforums.com/forums/problems-dealer-service/63664-torque-converter-shutter-aftermaket-moved.html" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229407558">Torque converter shutter and aftermaket (Moved) - Chrysler 300C Forum 300C & SRT8 Forums</A>
<DT><A HREF="http://www.jeepsunlimited.com/forums/showthread.php?p=8658946" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229402407">Transmission Lugging On Incline (fix) - JeepsUnlimited.com Forums</A>
<DT><A HREF="http://www.chargerforums.com/forums/showthread.php?t=8549" ADD_DATE="1231781375" LAST_VISIT="1231781375" LAST_MODIFIED="1229401261">Transmission Shuddering - Dodge Charger Forums</A>
</DL><p>
Unread 01-15-2011, 09:35 AM   #8
CMStango
any resolution?
Hello - i realize this thread is 2 years old, but I'm experiencing the same thing. When i come off the accelerator, it sounds like i'm going over small bumps while i coast. I've been assuming it's a transmission issue. Sounds like it's having a hard time downshifting (it's an automatic transmission). So before i get ripped off by a transmission guy, wanted to find out what yours ended up being. Thanks!
CMStango is offline   Reply With Quote Quick reply to this message
Unread 01-15-2011, 10:10 AM   #9
colinzj
2006 WK
There's a TSB for this for '05–'08 with the 4.7:
http://wkjeeps.com/tsb/tsb_wk_1801810.pdf
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote Quick reply to this message
