4.7L Spark plug change - Help please - JeepForum.com
post #1 of 8 Old 09-29-2013, 12:11 PM Thread Starter
cobosoxfan
Ok, I'm pretty handy in the engine compartment, but WTF were the Jeep engineers thinking with the configuration of engine and trans dipsticks over back passenger spark plug coil pack???
I looked up under there to see if there was any way to get to the bolt holding the trans tube, but it is in an unreachable spot at the top back of the engine. I'm ready to bend the tube out of the way with brute force but was wondering if there was a better way to get that plug out? I would hate to break it.
Thanks
2006 GC Laredo, 4.7L, OME HD up front and MD rear, RC spacers 1.5", Hankook ATM's 265/70/17
cobosoxfan is offline
post #2 of 8 Old 09-29-2013, 02:18 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
What year 4.7?
I know for a fact that the 06 and 07 can be done fairly easy. The rear most 2 are the most difficult but can be done with a plug socket, extension, and ratchet. No elbow needed.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 8 Old 09-29-2013, 02:51 PM Thread Starter
cobosoxfan
What year 4.7?
Thanks Mike, I ended up having to bend the trans dip stick out of the way. It was directly above the coil pack. The plug was cakework from there. I will say that I don't think it had been done before - ever! There was virtually no core left. After the plugs were done, I spent some time cleaning the Throttle Body, and Mass Air Sensor.
I then unplugged the neg battery cable, did the brake press procedure, and reconnected.
Lets just say this little service work made a huge impact. Quick pedal response, and the engine is running soooo dang smooth. Its awesome.
Thanks, Mike and the rest of the forum for the overall amount of info we as members can find!
post #4 of 8 Old 09-29-2013, 03:07 PM
JeepN4KC
JeepN4KC's Avatar
Glad you were able to get 'em.
If they'd never been done I'm sure you noticed a big difference.
~Mike~
WK
XJ
JeepN4KC is offline
post #5 of 8 Old 09-29-2013, 06:56 PM
bmuhlbach
There suppose to by done every 36,000 miles I just changed my 05's and the 2 back ones on pass. side are the hardest.
bmuhlbach is offline
post #6 of 8 Old 09-30-2013, 08:31 AM
Goldenknob
2007 WK
what is the brake press procedure your talking about?
Goldenknob is offline
post #7 of 8 Old 09-30-2013, 09:43 AM Thread Starter
cobosoxfan
Disco the neg battery cable open all doors, and depress the brake pedal for 30 seconds, a couple of times; as this is supposed to drain all residual electrical system power, so that the flash memory can relearn the new changes.
To be honest, Im not sure it actually works, as new electronics hold a small charge in them for quite a while. For instance after 5 minutes, I reconnected the battery and the radio still had all of the channels preset.
The flash memory in the CPU may be different??? I've heard it on so many diff truck forums I've been on, I just do it now. Urban legend? Internet Myth? Don't really know.
post #8 of 8 Old 09-30-2013, 09:55 AM
JRLT
2010 WK
Read somewhere else to just ground the positive cable(not the battery) against something metal. I just used a short cable and used the bolt the battery is grounded to on the frame.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
