? For the 4.7 guy's - Page 2 - JeepForum.com
post #16 of 23 Old 10-18-2013, 07:07 AM
modernblueWK
Does anyone know the cfm rating of the stock electric fan?
Im thinking it would be nice not to hear the roar of the fan when its freezing outside.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #17 of 23 Old 10-18-2013, 07:12 AM Thread Starter
overland-wk
2006 WK
His grand cherokee had two fans electric and mechanical fan we just took off the mecanical fan and still has the electric on. It never overheated it always stayed at normal temperature. And no i wont start a thread about an 08 gc overheating cause if it was i would just put it back on.
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #18 of 23 Old 10-18-2013, 08:27 AM
jay-h
Here is a good rule of thumb. A fan and clutch cost a good chunk of money. You can be pretty sure it would not be there if the engineers could get away without it. So, I would say that yes, the factory electric is not enough on its own.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #19 of 23 Old 10-18-2013, 08:38 AM
paroxysym
2007 WK
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #20 of 23 Old 10-18-2013, 08:55 AM
caulk04
2008 WK
In the Dakota, the PCM kicks the fan on at 210 coolant temp. The temp sender is on the outlet of the engine. Monitoring the PCMs temp signal showed that the engine ran no more than 10 hotter when simply removing the clutch fan. Fixing the non-problem brought it right down to where it was before hand.
For normal driving, the clutch fan is not needed. It's there for towing, extreme ambient temp and low speed service. All of these circumstances are ones that I would recommend putting it back on. Not sure of space available with the WK fan shroud, but it took all of 2 minutes to put it back on my Dakota.
Bottom line, if you don't want to do it, don't. Don't crucify this guy because he did.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #21 of 23 Old 10-18-2013, 10:08 AM Thread Starter
overland-wk
2006 WK
Thanks
Im sure if the hemi can do with out one the 4.7 can too.
Youtube channel
Bumsmodified98xj
post #22 of 23 Old 10-18-2013, 04:50 PM
R4TCHET
2005 WK
I think I read somewhere that if you don't have to tow package it doesn't come with the clutch fan. It really only does anything if you are towing a lot, I even have towed without the clutch fan and it was no problem. I still have my old clutch fan in my garage and can install it at any point in time. Now I wouldn't tow a huge amount long distances or in lots of stop and go driving without the clutch fan but my wk runs fine without the clutch fan I used to off-road 3-4 times per week during the summer on some pretty taxing trails and the engine would never go higher than if it had the clutch fan on anyways.
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #23 of 23 Old 10-19-2013, 07:13 AM
Goldenknob
2007 WK
I know this may not help, but my 07 4.7 does not have a clutch fan. Didn't when I bought it. Its got a pretty large electric fan though.
Goldenknob is offline
