3 Different Check Engine Light Codes - JeepForum.com
post #1 of 6 Old 03-18-2011, 07:42 PM Thread Starter
Ibraha
First post on the forums. Anyways, the check engine light came on today for my 2006 Jeep Grand Cherokee 3.7 V.6, so I went and had them checked out:
UC404
P0700
U0404
I found out that the P0700 one was "Transmission Control System Malfunction", but, I can't seem to find out what the other ones are. Any help would be greatly appreciated.
Ibraha is offline
post #2 of 6 Old 03-18-2011, 08:14 PM
Lt_JWS
2006 XK Commander
U0404- Implausable data recieved from ESM, and the P0700 could be from low transmission fluid, the NAG1 tranny wiring bulkhead connector gives trouble and leaks.... Do you have any leaks?
Cant find the "UC404"
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline
post #3 of 6 Old 03-18-2011, 11:47 PM Thread Starter
Ibraha
Hmm, haven't checked for leaks yet, will get on that tomorrow. Im curious on what exactly Implausible data received from ESM means.
Ibraha is offline
post #4 of 6 Old 03-19-2011, 08:27 AM
robpp
esm = shift module.
its the shifter. clean the contacts first; worth a try since the ESM = BIG BUCKS. v6 is 600 for the part.
search here for the process.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #5 of 6 Old 03-19-2011, 05:08 PM
drj33p
2006 WK
The P0700 Tranny could be one of many things,i had that code on my last Grand and it went into limp mode and it ended up being low voltage on start up in the battery.
So maybe a dealer or someone needs to find the fault within that code.
2006 WH Grand Cherokee Limited CRD.
1996 TJ Wrangler Sport.
"It's a Jeep Thing"
Not as many people down here understand.
drj33p is offline
post #6 of 6 Old 03-19-2011, 07:45 PM Thread Starter
Ibraha
I think I'll try and clean the shifter contacts, I'll update soon to see if that helps, thanks guys!
Ibraha is offline
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
97 ZJ check engine light...on, got codes but need help! jamoka3 ZJ Grand Cherokee Forum 5 06-20-2009 07:47 PM
Strange Check Engine light codes? klockdoc ZJ Grand Cherokee Forum 7 02-18-2009 07:25 AM
Check Engine Light with no codes? swataz ZJ Grand Cherokee Forum 2 09-22-2008 11:14 AM
Check Engine Light Codes -Joe- ZJ Grand Cherokee Forum 0 07-02-2008 02:02 AM
