3.7 Throttle body air box removal ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 3.7 Throttle body air box removal ?
Winter & Offroad TiresIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 12-12-2011, 02:11 PM   #1
speeddemon651
2007 WK
I was just wondering if anyone has attempted to remove the 3.7 L Throttle body air box for improved performance ? I currently have a K&N intake and can't see how funneling that into a large box then into the throttle body can be that great ? I'm just curious and have been thinking about fabricating up a elbow from the stock throttle body to my K&N intake tube. In my idea mind, direct piping with less impedance is better flow/performance and the air should tumble less before entering the throttle body.
speeddemon651 is offline   Reply With Quote Quick reply to this message
Unread 12-12-2011, 04:34 PM   #2
CmmdrDan
1. Where in MD are you located?
2. I have seen a few people make pvc air intakes. (not like that ******* gary's snorkel.)
CmmdrDan is offline   Reply With Quote Quick reply to this message
Unread 12-12-2011, 05:35 PM   #3
criket
2005 WK
#2 BWAHAHA!!!!
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline   Reply With Quote Quick reply to this message
Unread 12-12-2011, 05:50 PM   #4
Piepenbrok420
Originally Posted by speeddemon651 View Post
I was just wondering if anyone has attezmpted to remove the 3.7 L Throttle body air box for improved performance ? I currently have a K&N intake and can't see how funneling that into a large box then into the throttle body can be that great ? I'm just curious and have been thinking about fabricating up a elbow from the stock throttle body to my K&N intake tube. In my idea mind, direct piping with less impedance is better flow/performance and the air should tumble less before entering the throttle body.
You can get an intake tube from a liberty 3.7 it is in the place of our box
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline   Reply With Quote Quick reply to this message
Unread 12-13-2011, 11:56 AM   #5
speeddemon651
2007 WK
Huh, I'll have to check that out
Unread 12-13-2011, 02:17 PM   #6
Piepenbrok420
Only thing is, you'll have to solder on some extra wire for the sensor on the intake near the throttle body because the hole for the sensor on the liberty tube is on the other side, no big deal though, took me a whole 15 min. to get it all installed.
Unread 12-14-2011, 10:22 AM   #7
Piepenbrok420
Heres a pic, i need to fix it a little but i got the instructions off jg
Unread 12-14-2011, 12:40 PM   #8
Piepenbrok420
Dont know why its not uploading
Unread 12-29-2011, 03:16 PM   #9
speeddemon651
2007 WK
does anyone know the outside diameter for a stock 3.7 throttle body ? Trying to figure it out to order my new silicone elbow.
