3.7 Rough Idle - Page 2 - JeepForum.com
post #16 of 21 Old 04-05-2013, 04:50 PM
Benzie002
2011 WK
So I decided to clean the IAC motor (and the socket it was in) which was very dirty. While doing this, I was pulling the connector off the TPS sensor right above it and it broke apart. So, I replaced the TPS sensor and cleaned the IAC motor and the airflow sensor while I had it off and it is now purring like a kitten. No more rough idle. Probably the dirty IAC motor and possibly the TPS.
Good luck
Benzie002 is offline
post #17 of 21 Old 04-11-2013, 05:27 PM Thread Starter
Beardacus
Hey guys do you know where I can find a manual to work on the 3.7? I would like to clean the IAC motor and TPS sensor but I really have no idea where they are. I know it might sound silly but unfortunately it is the truth.
Beardacus is offline
post #18 of 21 Old 04-11-2013, 07:54 PM
Benzie002
2011 WK
The tps and iac are located under the throttle body air intake which is the black box in the center of the engine. Loosen the clamp at the large hose on the left of the box and the clamp at the back center of the box. Also disconnect the wire on the back left of the black box where the tube is connected. This is anther sensor. Then grab the box and wiggle it up and forward. The tps (black) will be on the right of the throttle body on top and the iac is silver right below it. Need a star driver to remove them both. Btw, you can only clean the iac.
Hope this helps. Good luck!
post #19 of 21 Old 04-11-2013, 08:14 PM Thread Starter
Beardacus
Benzie, thanks for the info.
On a side note do you know of a service manual for the 3.7? I think it would be really beneficial to me to understand how to work on this truck.
post #20 of 21 Old 04-12-2013, 07:20 AM
Benzie002
2011 WK
There are service manuals out there by Mopar and Haynes. I found this post by a search...
05-08 Grand Cherokee WK Service Manual
For those in need:
145mb
http://www.mediafire.com/?4q51ake1023nlb6
post #21 of 21 Old 04-12-2013, 08:24 AM Thread Starter
Beardacus
Thank you my NJ friend.
'08 WK - '13 JK
