3.7 has a rough idle - JeepForum.com
post #1 of 13 Old 04-09-2007, 10:15 PM Thread Starter
gsxr150
Today I picked up my rental Jeep 3.7. I'm in love with the truck, but when sitting in drive I get a weird vibration at idle. I seems the rough idle comes on and off....like 5 seconds on and 5 seconds off. Is that normal for the 3.7?
gsxr150 is offline
post #2 of 13 Old 04-09-2007, 11:46 PM
bull_blaster
2005 WK
i had the same issue, switched to higher octane gas and never had the issue again, but at the same time NO this should not be happing.
bull_blaster is offline
post #3 of 13 Old 04-10-2007, 03:48 PM
ennemme
2006 WK
I had a 3.7L on a '03 Cherokee (Liberty) but never had this problem...
WH Limited 4.7L V8 QuadraDrive II - M.Y. 06 "Midnight Blue" - Sunroof - NAV REJ - GoodYear Wrangler HP 245/65 R17 - Toyo Open Country WT 235/65 R17
ennemme is offline
post #4 of 13 Old 04-10-2007, 10:08 PM
cliff
Not normal with my 3.7 might be the AC compressor kicking in and out.
cliff is offline
post #5 of 13 Old 04-11-2007, 10:03 AM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
The Libby engine is a different engine then the GC 3.7. And I agree with Cliff, sounds like the compressor cycling.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #6 of 13 Old 04-13-2007, 04:12 PM
rooster p
is that good or bad for the AC compressor to be kicking in. (i'm a car noob)...mine does this as well
My Ride:
2005 Midnight Blue GC Laredo
My Mods:
Flowmaster 50 series, 3 10" MTX Subs, JBL 1200w Amp, Sony In-dash DVD player, Audiovox DVD Player, Tint all around
rooster p is offline
post #7 of 13 Old 04-13-2007, 04:59 PM
T-Rated
T-Rated's Avatar
The Air Conditioning compressor should only kick in if the AC is running, and will do so from time to time as the refrigerant warms and needs compressing/cooling again. So this is normal and good.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #8 of 13 Old 05-08-2007, 12:19 PM
indianrefining
It's hard to tell what kind of "bargain" gasoline has been put in a rental. It may just be totally gummed up. If you're going to have it for a while, throw in a bottle of Chevron TECHRON Gasoline Treatment, and run the snot out of it!
indianrefining is offline
post #9 of 13 Old 05-16-2007, 01:59 AM
tednelson83
mine does that, and i still havent yet fixed it. mine was a rental too.
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #10 of 13 Old 05-16-2007, 06:59 AM
NJD
My wife's '06 GC also has a rough idle, yet I have '05 and do not experience the same rough idle, at least not yet. I do notice that once it has an oil change it does idle smoother. I try and use the STP fuel injector cleaner every 3 fill ups just to try and keep the injectors and the fuel system somewhat cleaner.
As far as gas, we both fill up wherever the gas is cheaper that day, but usually the same stations, so I don't believe it's a gas issue. As far as I'm concerned gas is gas, they all get it from the same terminals. I know I've heard it before that it differs from one brand to the next, but I worked at a gas station in my college days, and the owners also owned a trucking business where they delivered gas to independent gas retailers, basically what they do is they would call there terminals and find out who had the lowest prices, then they would buy from them, after all do you think the no name gas stations have their own refineries?
NJD is offline
post #11 of 13 Old 05-18-2007, 07:59 PM
Bad Habit
I've also noticed this in my wife's 06 3.7. I wouldn't really describe it as a rough idle though. To me, it's more of an exhaust drone or engine harmonic at that rpm. When it does it, if you pop the shifter up into neutral it will go away. Also if you just barely put the slightest pressure on the gas pedal it will go away. IMO, the in-gear idle is about 50 rpm too low.
Bad Habit is offline
post #12 of 13 Old 05-31-2007, 08:48 AM
sw99
Really? What is different?
sw99 is offline
post #13 of 13 Old 05-31-2007, 10:13 AM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Sorry about that, I was thinking of the JK engine. The 3.7 in the GC started out as the KJ engine, they just made a lot of changes to it since then.
Originally Posted by wkjeeps.com
Significant changes in the 3.7-liter include a revised cam profile and new valve lash adjusters. These changes improve the engine smoothness at idle. To ensure quiet operation, a new thick-wall composite manifold is new for 2005, as are structural improvements to the air box and resonator. The cylinder head has been redesigned, increasing the compression ratio to 9.7:1. The 3.7-liter now uses plastic cylinder head covers.
242 Has a Rough Idle. Some_Anchovies ZJ Grand Cherokee Forum 30 10-04-2009 09:39 AM
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 03:53 PM
rough idle fearthedeere69 ZJ Grand Cherokee Forum 8 08-13-2007 10:34 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
rough idle baroc ZJ Grand Cherokee Forum 0 03-18-2007 08:06 PM
