3.0L CRD Oil Change Procedure/Any Tips - Page 3 - JeepForum.com
post #31 of 42 Old 11-10-2012, 07:31 AM
bugsybdb
2007 WK
So would the mobil 1 TDT be fine for my 07 grand cherokee crd as well even though it has a DPF?
bugsybdb is offline
post #32 of 42 Old 11-10-2012, 07:52 AM
fishinbama
2007 WK
No, it wouldn't because it would have too much ash and could eventually stop up your dpf. Also, you might want to post this same question on bobistheoilguy. They could give you a more definitive answer.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #33 of 42 Old 09-06-2016, 11:43 PM
omsok
omsok's Avatar
2007 WK
Originally Posted by fishinbama View Post
Basically a few things to remember: ( I just did this today again)
1. oil capacity is 10 Quarts
2. drain oil from drainplug and make sure to remove oil filter while it is draining.
3. when refilling, fill half of oil through oil filter.
4. wait 15 minutes before cranking.
Optional: curse Mercedes lots and lots while waiting impatiently on oil to go down
Why are people refilling half through filter housing? Does anybody know?
omsok is offline
post #34 of 42 Old 09-07-2016, 12:34 AM
ggrassmid
2008 WK
Supposedly you can spin the front main bearing. While I'm not convinced this could happen, it does make filling a little quicker since you are running some oil down both sides of the valve train.
ggrassmid is offline
post #35 of 42 Old 09-07-2016, 07:47 AM
08rubie1
Buy a futomot drain valve.. makes draining a breeze
08rubie1 is offline
post #36 of 42 Old 09-07-2016, 11:37 AM
Brit30-06
2008 WK
I do not understand why this is done. Surely the oil just falls to the sump regardless of whether it is put in the filter housing or filler cap. I am not saying they are wrong I am just saying I do not understand.
Brit.
Brit30-06 is offline
post #37 of 42 Old 09-07-2016, 12:36 PM
Hendrix9
2007 WK
Brit.
I thought it had to do with the cool room temperature oil dumping into the hot engine cooling off that half of the engine more than the other side which can cause a problem of some sort. (even though we've never known of anyone who had it happen....)
I still do it, it only makes it take a few minutes longer vs just dumping it all down the fill tube. I'd rather do it for no reason than find out that what seemed silly had a purpose.
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is offline
post #38 of 42 Old 09-07-2016, 12:45 PM
Tango.
2008 WK
It was Merlin's idea. He thought it could run dry for a few seconds.
Life is hard-John Wayne
Tango. is offline
post #39 of 42 Old 09-07-2016, 07:04 PM
omsok
omsok's Avatar
2007 WK
Oil in Filter side. Danger Warning
As somebody above stated, I got to thinking about it and also think the oil would be in the pan, just the same as if the car had been, turned off, and restarted, which if have done an oil change, I would hope it had.
I had also been doing this with past oil changes, and actually did it with my last one, on the weekend.
I spoke to a friend of mine who was a senior mechanic at Chrysler Jeep, and was trained extensively and worked on these motors, and now works at Subaru.
He said the only time they do something like this is if there has been some sort of major tear down on the engine. In that case, they will also disconnect the ignition, or fuel (in diesel case) and turn the motor over until the pressure comes up to psi before firing the engine up. In this case they use an external gauge, not the "oil light" which trips off around 8 psi.
I also asked Conflicted racer this question after seeing what he recommended and finding he recommended the same practice of pouring 4-5 quarts down the filter side.
For those of you that do not know Conflictedracer, it is one of the best WK sources of mechanical and maintenance info on the web.
https://conflictedracer.wordpress.co...erokee-diesel/
The Danger part.
One thing I have found is some people (not necessarily WK CRDs) are accidentally dropping plastic, or aluminum foil slivers into the oil filter center hole when priming their filters, or "dry" side of their v blocks. This can have catastrophic consequences. If you do put oil down your filter hole, please make sure it is only oil.
omsok is offline
post #40 of 42 Old 09-07-2016, 07:09 PM
omsok
omsok's Avatar
2007 WK
Oil drain Ball valve!
Yep, one of the best investments ever. I don't even need the hose to stop oil splashing on skid plate because I have the 90 degree extension.
I Park the Jeep, let it cool, put the catch tub under, and flip the valve and forget about it for awhile. (N.B) I often take neg post off battery when draining oil like this because with E-Z drain valve I can dump the oil without actually using nay tools, or getting into shop mode while letting the engine drip drain.
Don't want anybody to start Jeep forgetting it is oil less. I am sure it has happened before.
omsok is offline
post #41 of 42 Old 09-07-2016, 07:16 PM
Tango.
2008 WK
Merlin is the only one that I know of that came up with that idea. He's a really bright guy and knows the OM642 better than most folks. If you search on here you find his posts about this.
I'm sure it's a fantastic idea. I never do it.
Tango. is offline
post #42 of 42 Old 09-08-2016, 11:13 AM
Brit30-06
2008 WK
Hi Tango
I read the Merlin thread. I still do not understand why oil reaching the sump via the filter housing is different than oil reaching the sump from the filler tube. Does no harm though I suppose. I wonder if the Mercedes mechanics use this fill process.
Shame Merlin no longer visits the site.
Brit.
Tips, help: Trans. fluid change out... Panchojeep ZJ Grand Cherokee Forum 0 02-05-2010 10:49 PM
procedure from 4hi to 4lo 69speed ZJ Grand Cherokee Forum 3 10-08-2007 09:33 PM
Change a downstream Oxygen Sensor, Any hints or tips? Gonna Need Help with this one! Polaris Junkie ZJ Grand Cherokee Forum 17 09-05-2006 08:15 AM
Cleaning procedure Endurancevm ZJ Grand Cherokee Forum 5 03-18-2006 05:08 PM
Gonna change rear brake pads on a '95 ZJ. Any tips? 92TripleBlack ZJ Grand Cherokee Forum 0 11-15-2002 10:55 AM
