3.0L CRD Oil Change Procedure/Any Tips - Page 2 - JeepForum.com
post #16 of 42 Old 10-30-2012, 12:58 PM
pixelcodex
2007 WK
Originally Posted by justa4banger View Post
Directions for an oil change.
Get Mityvac. It hold 7 quarts...
Warm engine up all the way, best to do the oil change when the engine is hot...
Then insert tube in the dip stick and evacuate the system, once the oil is half way in the tank, slow down as to not overfill the mity vac, it has a cut off, but i like to stop it on my own.
dump that oil in a container and evacuate the rest out.
Take the oil filter and replace it with new Orings, remove the tube from the dip stick...
Refill the oil, 5 ltr's in the oil filter area and 5 in the engine.
install oil filter
Crank engine..
I buy my oil from RMEuropean.com they also carry filters. i buy it when its on sale or i get a coupon.. free shipping in the lower 48. usually cost me 70.00 or so...
No climbing under the truck, no mess, just smooth sailing.
I haven't been under the truck in 3 years....
At 100k i'll take the drain plug out and see what i find...
trucks been running great with no issues.
I thought the engine takes 10 quarts, not 10 liters? I am more surprised in your case, as I imagine some oil is always left when you change it with this method. Or am i incorrect in assuming so?
I like the idea of a Mytyvac, just wanted to get confirmation from somebody who uses it such as yourself...
pixelcodex is offline
post #17 of 42 Old 10-30-2012, 01:47 PM
Radcrd
2007 WK
I have been using extractor pumps on all my cars since around 2001. Much easier and less of a mess especially when the oil filters are located on top. No need to remove skid plates and get dirty
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #18 of 42 Old 10-31-2012, 09:07 AM
DieselDevotion
2007 WK
Originally Posted by fishinbama
Definitely get a fumoto drain valve for your 3.0 liter. My last oil change was such a breeze. I hook up a short piece of hose and put the other end in my cut off drain bucket. Flip the switch and that's it. First time I've never gotten a drop of oil on myself.
+1 Fumoto is the way to go!
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #19 of 42 Old 11-02-2012, 07:03 PM
Tango.
2008 WK
Could you post the part number for his for a 2008? and where did you get it from?
This is what I need so I don't have to drop the steel skid plate every time.
Tango. is offline
post #20 of 42 Old 11-02-2012, 07:43 PM
BAH101
2008 WK
Here ya go: http://www.quickoildrainvalve.com/se...ts.asp?cat=102
I got the one with the nipple. I have a six in piece of vinyl tubing I just put over the end of the nipple then reach up and turn the valve. Works awesome.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #21 of 42 Old 11-02-2012, 08:04 PM
Tango.
2008 WK
Thanks !!!
Tango. is offline
post #22 of 42 Old 11-06-2012, 06:05 PM
Demeech
2008 WK
sorry, the valve connects right to where the oil drain bolt would normally be? And you just leave it on there forever? and when you want to change the oil you just add the hose to the downside and then turn it to flow?
Demeech is offline
post #23 of 42 Old 11-06-2012, 06:11 PM
DieselDevotion
2007 WK
Yes!
98 TDI Jetta
post #24 of 42 Old 11-07-2012, 04:15 AM
Tango.
2008 WK
Exactly. You can also leave the hose attached, just plug it so nothing gets in it.
Without it you need to drop the skid plate everytime you change the oil.. or the oil goes all over the place.
Tango. is offline
post #25 of 42 Old 11-07-2012, 10:00 AM
dieseljeep07
dieseljeep07's Avatar
2007 WK
Installed my Fumoto Plug with my last oil change, I am excited to see how nice it works with this next oil change.
dieseljeep07 is offline
post #26 of 42 Old 11-07-2012, 10:41 AM
jiggadog
2008 WK
edit
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #27 of 42 Old 11-09-2012, 06:57 PM
bugsybdb
2007 WK
I dont know if this is the right place to ask about this, but I have a question about oils. I see that alot of people are running Mobile 1 ESP for their 3.0 CRd's. I am wondering if anyone knows of an oil that meets the MB 229.51 and also meets the VW's 505.01. My wife has the 04 Jetta TDI 1.9l and I have the 07 Grand Cherokee 3.0L CRD. I am would like to find an oil that meets both standards so I could buy it in bulk and also have the same oil for both cars.
bugsybdb is offline
post #28 of 42 Old 11-09-2012, 07:11 PM
SSF556
2008 WK
what spec for the VW?
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #29 of 42 Old 11-09-2012, 09:02 PM
bugsybdb
2007 WK
The VW's says for the TDI it has to use VW approved 505.01 oil.
bugsybdb is offline
post #30 of 42 Old 11-09-2012, 10:58 PM
fishinbama
2007 WK
I had an 05 passat tdi that was specced for 505.01. I believe that the 229.51 would be fine in the 505.01 spec cars. 505 is an older spec than the 229.51 and it was created to protect the fragile camshafts in the tdi. Many did well using mobil turbo diesel truck in the tdi. I too, plan to use some Mobil one TDT in my om642 now that I have no dpf.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
Tips, help: Trans. fluid change out... Panchojeep ZJ Grand Cherokee Forum 0 02-05-2010 10:49 PM
procedure from 4hi to 4lo 69speed ZJ Grand Cherokee Forum 3 10-08-2007 09:33 PM
Change a downstream Oxygen Sensor, Any hints or tips? Gonna Need Help with this one! Polaris Junkie ZJ Grand Cherokee Forum 17 09-05-2006 08:15 AM
Cleaning procedure Endurancevm ZJ Grand Cherokee Forum 5 03-18-2006 05:08 PM
Gonna change rear brake pads on a '95 ZJ. Any tips? 92TripleBlack ZJ Grand Cherokee Forum 0 11-15-2002 10:55 AM
