3.0L CRD - Dana 44 - 12_bolt Differential - HELP - Page 2 - JeepForum.com
post #16 of 28 Old 10-21-2013, 08:55 PM Thread Starter
ryann04
2008 WK
Pictures of my rear diff. Maybe someone could take a look at these and shead some light as to how bad the damage is/isn't?
http://s66.photobucket.com/user/ryan...ry/jeep%20diff
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #17 of 28 Old 10-22-2013, 05:01 AM
jediknight
2008 WK
Originally Posted by ryann04
Pictures of my rear diff. Maybe someone could take a look at these and shead some light as to how bad the damage is/isn't? http://s66.photobucket.com/user/ryan...ry/jeep%20diff
uuuuuhm,
Why do you say your diff is damage ???
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #18 of 28 Old 10-22-2013, 08:22 AM Thread Starter
ryann04
2008 WK
Originally Posted by jediknight View Post
uuuuuhm,
I'm asking if it is damaged, it looks fine to me.
I ran it low//almost dry of oil. It made a loud clunking noise and smoke out of the fill hole.
So I'm pretty sure at the least, my bearings are toast.
ryann04 is offline
post #19 of 28 Old 10-22-2013, 08:42 AM
Jeepforthewin
2010 JK Wrangler
It looks good to me. Don't see any metal shaving's or chunks and don't see any scrapes or dings anywhere. I would still possibly swap the bearings to be safe though.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #20 of 28 Old 10-22-2013, 08:45 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
OP -
Have you refilled the diff and run it up to see what happens?
If it's indeed damaged then you've nothing to lose.
If it's good to go then it's good to go.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #21 of 28 Old 10-22-2013, 08:48 AM Thread Starter
ryann04
2008 WK
OP -
I love your logic. No I haven't tried this yet.
I'm sure it wont work in my favour though.
ryann04 is offline
post #22 of 28 Old 10-22-2013, 08:51 AM
jediknight
2008 WK
I hear ya ... Its never fun to see smoke coming out from anywhere (except exhaust..). But i think at this stage you need to go with what you see.
I'd tried to look for any loose parts / cracks on some parts. If this is ok, I'd fill her up with oil and test drive and see if she drives ok ?
post #23 of 28 Old 10-22-2013, 08:58 AM
Jeepforthewin
2010 JK Wrangler
Originally Posted by JeepN4KC
OP - Have you refilled the diff and run it up to see what happens? If it's indeed damaged then you've nothing to lose. If it's good to go then it's good to go.
I agree with this!
post #24 of 28 Old 10-22-2013, 10:34 AM
Radcrd
2007 WK
Spend the 30$ on fluid, fill it and see what happens. Why did it run dry? Was there a leak?
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #25 of 28 Old 10-22-2013, 10:44 AM Thread Starter
ryann04
2008 WK
Ran dry due to axle seal leaks. (both sides).
I am taking it to a guy who is willing to put new bearings in for $600.00, then fill it with oil and go from there. Try to see if I will "LUCK" out or not.
I'll keep ya posted.
ryann04 is offline
post #26 of 28 Old 10-24-2013, 11:31 AM Thread Starter
ryann04
2008 WK
Problem fixed!!
Crown and pinion were fine.
They did all bearings/etc for rebuild...
$600/ for rebuild (labour + rebuild kit)
$80/ for machining (had to machine the yolk??)
Had to heat up some parts that were ALMOST welded together to remove them properly and not damage anything they could save.
$700~ after tax. No noise, no problems, 100% perfect!
Now that's what I call service. The shop I went to REPAIRED the problem. Where as the STEALERSHIP wanted to just replace all the parts and call it a day. I must say, I hope we don't loose the few repair shops we have left and become a "just replace it with another one, instead of fixing it" civilization.
The best part of it all is, I dropped it off first thing in the morning, they got me in asap, and had my vehicle repaired and ready for pick-up at 3pm the same day!! Talk about service!!
+REP for http://www.protracgear.ca/ (who performed the great service)
defenitely recommended for those in the Alberta/Canada region and needing driveline repairs.
ryann04 is offline
post #27 of 28 Old 10-24-2013, 03:59 PM
jediknight
2008 WK
Problem fixed!! Crown and pinion were fine. They did all bearings/etc for rebuild... $600/ for rebuild (labour + rebuild kit) $80/ for machining (had to machine the yolk??) Had to heat up some parts that were ALMOST welded together to remove them properly and not damage anything they could save. $700~ after tax. No noise, no problems, 100% perfect! Now that's what I call service. The shop I went to REPAIRED the problem. Where as the STEALERSHIP wanted to just replace all the parts and call it a day. I must say, I hope we don't loose the few repair shops we have left and become a "just replace it with another one, instead of fixing it" civilization. The best part of it all is, I dropped it off first thing in the morning, they got me in asap, and had my vehicle repaired and ready for pick-up at 3pm the same day!! Talk about service!! +REP for http://www.protracgear.ca/ (who performed the great service) defenitely recommended for those in the Alberta/Canada region and needing driveline repairs.
...A well ended story Good thread Ryan ! Thanks
post #28 of 28 Old 10-24-2013, 04:22 PM
Jeepforthewin
2010 JK Wrangler
Glad to hear all is good now!
