3.0 diesel, oil leak at the oil cooler? - JeepForum.com
post #1 of 2 Old 03-05-2014, 02:20 PM Thread Starter
gcirillo
First, this is a bit of a trick question. The car in question is a Mercedes GL320 (2008) but it has the same 3.0L turbodiesel as the WK.
Benz dealer wants $2,500+ to change a gasket between the oil cooler and the intake manifold. It's a cheap part, but hours and hours of labor to take everything off the top of the engine.
Is this a problem with the Jeep diesels too?
Would I be crazy to get a quote from a big Jeep dealership for the job, or should I try a Sprinter repair shop? I am fairly ambitious as a DIY guy, but I had an independent Benz shop turn me away claiming that this job was too much for them!
gcirillo is offline
post #2 of 2 Old 03-05-2014, 02:42 PM
suzieque
2008 WK
same engine and same problem on jeep. there was a guy that posted a quote for the work a couple weeks back.
http://www.jeepforum.com/forum/f67/3...70/index2.html
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
