3.0 diesel gear changes - JeepForum.com
post #1 of 17 Old 04-12-2014, 11:51 AM Thread Starter
joeazzj
We just changed the gears on my friends jeep the dealer can recalibrate for the gear change . 3.73 to 3.07's a ton better ! Instead of motoring down the hwy at 70 and 3000 rpm it's more like 2000 . It's only if you drive the hwy more other wise you won't see the improvement. Just thought I'd share.
97' zj stock till I buy up all my goodies ! 318 242 waiting to go in .
joeazzj is offline
post #2 of 17 Old 04-12-2014, 12:16 PM
caddydaddy
2007 WK
That's a big drop in RPM! How does the gear change affect taking off? I'd consider it, but I have a 12 foot enclosed trailer that I tow. I wouldn't want to lose the pulling power.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
196,000+ miles!
caddydaddy is offline
post #3 of 17 Old 04-12-2014, 12:24 PM
chrali
2006 XK Commander
What did that set you back?
Sent from my GT-I9300 using JeepForum
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #4 of 17 Old 04-12-2014, 12:27 PM Thread Starter
joeazzj
It's 2200 @ 70 Ya I wouldn't do it then. Unless you upgrade the torque converter a shift improvement kit and a cooler with a separate fan that turns on when it gets hot . What transmission does it have ?
joeazzj is offline
post #5 of 17 Old 04-12-2014, 12:30 PM Thread Starter
joeazzj
joeazzj is offline
post #6 of 17 Old 04-12-2014, 12:40 PM Thread Starter
joeazzj
It was 1800 had to buy a front commander axle for the 3.07's but I'm sure you can just order it the rear is a 8 1/4
joeazzj is offline
post #7 of 17 Old 04-12-2014, 03:21 PM
chrali
2006 XK Commander
Nice work, any idea how your fuel consumption is improved?
GDE HOT Tune
chrali is offline
post #8 of 17 Old 04-12-2014, 03:29 PM Thread Starter
joeazzj
I'll know in a few weeks when he's back in town
joeazzj is offline
post #9 of 17 Old 04-12-2014, 03:39 PM Thread Starter
joeazzj
I just looked up peek torque it's 37? @ 2000 so it should pick up a good amount
joeazzj is offline
post #10 of 17 Old 04-13-2014, 02:14 PM
Red_liner740
How did the ECU and transmission take it?
I remember reading about another member who was in the middle of the swap and ran into huge issues with the transmission ECU going crazy due to the fact that it was seeing different wheel rpm vs transmission output RPM.
Could you give us a bit more information on the software side?
Just wanted to add that i've added taller tires two weeks ago and so far the EVIC is reading the same MPG's while the vehicle is traveling 10% farther distance.
Red_liner740 is offline
post #11 of 17 Old 04-13-2014, 02:27 PM Thread Starter
joeazzj
We took it to the dealer and the go in and recalibrate for the new gear ratio . Only problem we had to school the dealer on their hand held . The ring and pinion for the 8 1/4 you can get the 3.07 but the front is were the problem is but you need to order a ring and pinion for a 07 commander .
joeazzj is offline
post #12 of 17 Old 04-13-2014, 03:12 PM
fishinbama
2007 WK
I tried 2 different dealers and they either couldn't or wouldn't do it for me, back when I did mine.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #13 of 17 Old 04-13-2014, 03:25 PM Thread Starter
joeazzj
We're do you live ? Maybe find someone who works there it's in the computer but the don't know it. Like I said it's Dona and on the road .
joeazzj is offline
post #14 of 17 Old 04-13-2014, 04:48 PM
SSF556
2008 WK
4wd or 2wd?
I am also confused because I have never done 3000 rpms at 70mph....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #15 of 17 Old 04-13-2014, 05:01 PM Thread Starter
joeazzj
What gears do you have ? Peak torque is at 2000 rpm the higher the rpm above that the more gas your waisting
joeazzj is offline
