3.0 CRD fuel pump noise - Page 2 - JeepForum.com
post #16 of 41 Old 06-02-2013, 08:15 PM
Drewd
http://centralmotivepower.com/bosch/ may be able to get the COFV for you. Please let me know how your experience is with them and how much they charged you for the item.
Please share the part/item number for it cuz I don't trust I got the correct COFV for my cp3 pump even though it works fine.
Drew
Drewd is offline
post #17 of 41 Old 06-05-2013, 10:08 AM Thread Starter
BWP1000
2007 WK
I have been doing a bunch of calling around it looks like the Bosch Part number for the COFV is F 00N-201-320. It sounds like it is the same as what is in the Dodge 6.7 Cummins. I am trying to see if I can find a used one around.
Drew
Does that sound like the one they finally sent you?
07 Jeep Grand Cherokee 4x4 Overland 3.0 CRD (wife's)
04 Ram 2500 4x4 Cummins (mine)
BWP1000 is offline
post #18 of 41 Old 06-05-2013, 01:50 PM Thread Starter
BWP1000
2007 WK
Well in my search for a used COFV or a CP3 pump. I talked to a mechanic that suggested checking the Rail pressure relief valve. He said there should not be any fuel coming out of the rail to the tank return line. So I unhooked the hose where it tees in to the return line on top of the motor. sure enough it was pumping a lot of fuel out of the rail. So now I am trying to find the Bosch part number for the Rail or the Relief Valve. They Can not seam to cross the Mercedes Number that is on the Rail. If anyone has those numbers please let me know. Thanks
Also I was able to take the COFV out with out removing the Pump. Just need to take off the pipe going from the inner cooler to the turbo. With a 16mm socket and a swivel you can get it out. It makes it a little harder to keep it clean on the install though.
BWP1000 is offline
post #19 of 41 Old 06-05-2013, 08:16 PM
Drewd
Don't you read anything I post? My first post had you to check output of rail pressure relief valve as part of your troubleshooting?
Am I wasting my time typing and researching parts and suppliers for you? I guess you would rather make your own mistakes then learn from others?
Typically, if the fuel rail pressure relief valve is bad, you'll have trouble starting (long starts/hard starts) because the fuel rail is unable to build up the minimum needed pressure (I think its 5000psi) to triger activation of fuel injectors.
I'm done posting on this topic. I've given you a source for a COFV and it doesn't appear you wish to follow my advice as the only person on this forum who has had the same exact problem and fixed it after wasting money replacing the in tank pump twice, the fuel control valve on the CP3, and a new fuel rail with a new rail relief valve, and finally the CP3 pump which only needed a COFV.
A used COFV could be bad and you can be chasing your tail if you test a defective COFV. You are willing to spend $300-$400 for a fuel rail relief valve but not less than $100 for a COFV? I dont' get it.
Good luck, here are some parts numbers for you.
This is the actual Bosch part number Car Part BOSCH 0 281 002 826 Pressure Control Valve, common rail system
ManufacturerBOSCHNumber0 281 002 826DescriptionPressure Control Valve, common rail systemOriginal numbers 6420780249, A6420780249Valve TypeDiesel
Analogous \ Similar Parts of BOSCH 0 281 002 826
ManufacturerNumberDescriptionMERCEDES 642 078 02 49Pressure Control Valve, common rail systemMERCEDESA 642 078 02 49Pressure Control Valve, common rail system
Mercedes Benz Fuel Rail
Item Specifics:
  • Model: A642 070 21 94/003 <-- I used the 94/004 part instead (Its a newer version of the rail)
Drewd is offline
post #20 of 41 Old 06-06-2013, 09:25 AM
Tuco
Tuco's Avatar
2007 WK
I have this part in case you still need it. I sent you a PM
07 WK CRD Limited
Tuco is offline
post #21 of 41 Old 06-07-2013, 04:46 AM
jediknight
2008 WK
Good thread by the way!
Keep us posted please !
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #22 of 41 Old 06-07-2013, 08:43 AM Thread Starter
BWP1000
2007 WK
Drew
I thank you for your help I am sorry you don't like the way I do thinks. I did Call Central Motive Power they where not able to find the COFV off the pump numbers I gave them they Could get me a whole pump. I called a local big truck Diesel and he got me in contact with Diesel Control Technicians Inc.
I did not think it was the rail because it did not throw no codes and i was not sure what line to take apart to check the flow. I was going to Order A COFV but the guy Tech at DCT Inc stopped me because he was not sure that was the problem. I really don't want to throw anymore money at this jeep if i don't have to. I have already spent 800+ on a fuel pump.
BWP1000 is offline
post #23 of 41 Old 06-08-2013, 09:12 PM
Drewd
This vendor is able to obtain the cascade overflow valve for the 3.0L MB CRD engine in our WK's. I don't know what he charges but whatever it is, I'm sure it'll be cheaper than buying a new or used replacement CP3.
Erric Hoesli
Hoesli Diesel Service
1-800-487-1001
www.hoeslidiesel.com
Drewd is offline
post #24 of 41 Old 06-10-2013, 10:09 AM
Drewd
Now you know why I replaced my CP3 pump but eventually did find a COFV. Now I have a backup CP3 but am confident our CP3s will last a long time and that to expect future FCV or COFV failures instead.
Originally Posted by BWP1000 View Post
Drew
Drewd is offline
post #25 of 41 Old 06-14-2013, 09:59 PM
Drewd
The suspense is killing me.
Drewd is offline
post #26 of 41 Old 06-17-2013, 10:36 PM Thread Starter
BWP1000
2007 WK
went a head and ordered COFV from a shop in topeka ks. suppose to be in the next couple days. I will let you know how it all turns out and the supplier info if i get the right thing.
BWP1000 is offline
post #27 of 41 Old 06-26-2013, 09:15 PM
Drewd
bump?
Drewd is offline
post #28 of 41 Old 06-27-2013, 12:44 PM
jediknight
2008 WK
Yeah is the noise gone after changing the valves ?
post #29 of 41 Old 06-29-2013, 08:44 PM
Drewd
Regardless, if you have fuel pump noise, my tips should help resolve your issue if it arises. The cascade overflow valve was the issue with my vehicle with the same exact noise.
I suspect OP had some knuckle head local mechanic or pal convince him to replace some expensive part that wasn't bad. BPW1000, I apologize if I appeared rude. I was just baiting you a bit because I was dying with suspense (I'm unfortunately very unpatient) to see if the COFV replacement did the trick
Drewd is offline
post #30 of 41 Old 06-30-2013, 10:39 PM Thread Starter
BWP1000
2007 WK
I got the COFV put in the other day. So far No noise. I still have fuel coming out of the rail relief valve. Does not seam to be as much as before but still quite a bit. I still want to run some test to see what all changed. I am not sure when I will get a chance to do that. I am pretty swamped at work, plus an addition I'm putting on the house, and a baby on the way.
I got the COFV from Injection and Turbo INC. for $68.26 shipped to there shop from bosch. The new one is on the right in the picture. some of the holes look to be a little bigger.
BWP1000 is offline
