3.0 CRD DIESEL BHP Torque and 0-60 MPH times? - JeepForum.com
post #1 of 6 Old 04-19-2014, 03:43 AM Thread Starter
Penguin_Jeep
2006 WK
Hi All,
My jeep was laid up a year ago with mysterious issues, but with that aside I thought I'd share my result here to see what you make.
My jeep has NEVER been remapped and currently has an intermittent issue with the EGR circuit range and the transmission shift module - so any suggestions in those areas would be appreciated.
I have OBD screen shots from my Palmer performance OBD software on iPad, however JF doesn't allow upload so will do it from laptop when I get home.
The results
308hp (factory is apparent 218)
547 lb ft of torque. (factory 376)
0-60MPH 8.1 seconds (continental 0-100Km/h)
Remember this is the Diesel.
Any thought on this?
Penguin_Jeep is offline
post #2 of 6 Old 04-19-2014, 09:15 AM
jjt250
2007 WK
The 0-60 time seems about right but those power and torque figures are definitely off.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #3 of 6 Old 04-20-2014, 08:09 AM Thread Starter
Penguin_Jeep
2006 WK
OBD2 Software
Think maybe the palmer software is not calibrated?
Anybody else use Palmer OBD software?
post #4 of 6 Old 04-20-2014, 09:54 AM
hulikner
2008 WK
If you can calibrate it then yea. You can't get close to those hp/tq numbers stock. Otherwise your thing just doesn't give even close power numbers.
hulikner is offline
post #5 of 6 Old 04-20-2014, 10:12 AM
222Doc
222Doc's Avatar
unless these numbers are done on a Dyno first stock then with what ever on the same dyno same settings its all doody squat. I would bet that that soft ware is just putting out numbers to prove what ever they claim.
Torque is torque no matter how its made. with 550 i would think that it would smoke the tires off
222Doc is offline
post #6 of 6 Old 04-21-2014, 03:17 AM Thread Starter
Penguin_Jeep
2006 WK
Speaking of smoking, it will light up the wheels.
I'm think I need a fellow WK/WH or XK commander owner to plug into and compare. Any volunteers over in the UK?
